broken cam sproket?????
This is a discussion on broken cam sproket????? within the Yamaha TTR50 forums, part of the General Talk category; ok i finaly got the bike together after blowing 1st 2 times and about 4 months i started it up and let it warm up ...
Results 1 to 1 of 1
    toyotakid's Avatar
    Dec 2005
    Stratham, NH
    ok i finaly got the bike together after blowing 1st 2 times and about 4 months i started it up and let it warm up eavrything seemed fine. then i went for a about mile and a half ride down the road in 3rd pined i heard this clicking noise and i cut the engine. then after trying to get it running again (check spark, compression) but no fule so i rebuilt the carb and still wasnt getting fule so i took off the valve covers and turned over the motor and the valves wernt moveing so i took off the cam cover and saw i broke off the tooth that holds the sproket in place.
    how did this happen was it that maby i forgot to tighten the cam sprocket or was it going wide open for 5min or something ealse?????
    TTR50, two brothers pro bar kit, HD springs front and back (.25" spacer), tall seat, Classic honda +2.5 swing arm, HD foot pegs, jet kit, air filter, tires(sudded,dirt,motard), custon front fender, blue hubs and black rims...etc
    http://profile.myspace.com/index.cfm...endid=76229132
