does anyone know if a crf50 rear shock (i shock) will fit a ttr 50?
thanks- dave
This is a discussion on rear shock question within the Yamaha TTR50 forums, part of the General Talk category; does anyone know if a crf50 rear shock (i shock) will fit a ttr 50? thanks- dave...
thanks- dave
Yes, as long as its a non res.
resi will work also but you will have to mod the seat if i remember right
I run an Ishock WITH res on my ttr with no modding done to anything.You have to run the shock with the res at the bottom but it works fine.Im not saying the ishocks are good or anything because I actually think their a POS and really wouldnt suggest one to anyone.
MotoHP
AHP Minis
yeh they blow to quickly, i actually will be using a fast ace shock,... lets see how it is going to last... i hope to have good luck with it!!
i think i am going to pick up a works rear shock for the CRF50 and through it on. they dont make one for the TTR50 yet.
06' TT-R50. TBR front springs, Yoshimera pipe, GYTR stage 1 filter, TBR tall seat, Red Barron MX bar kit, Pirelli SL26's.
GLMMRS.com #13 SRH KMK
04´ KFX 400-moded- gone in spring
07 KX-F 250 in the spring
"back the he11 off if you got stems and seeds"
I Heard It Was Bad To Run A Shock With A Res Upside Down, Can Any One Confirm?
