Timing A Ttr 50
Timing A Ttr 50
This is a discussion on Timing A Ttr 50 within the Yamaha TTR50 forums, part of the General Talk category; Well after struggling with the feuling and checking the timing i got it running pretty good my only concern is the gearing which is too ...
Results 1 to 9 of 9
Thread: Timing A Ttr 50
    is getting old.!!!!
    BUZZ 50s BROTHERHOOD's Avatar
    Oct 2006
    south wales..uk
    Is There A Rev Box Availiable For The Ttr 50 And Need Advice..???
    Well after struggling with the feuling and checking the timing i got it running pretty good my only concern is the gearing which is too high 13/39 and the rev limiter ,as i seem to be hitting it very early comparing it to my crf 88 engine,this could be down to the gearing or i just need a rev box to up the rev limit.Any one else hitting the rev limiter since fitting a big bore kit or is it still over fueling because since i put a 85 main jet in it the misfire at the top end has gone but like i said i think im hiting the limiter as it does'nt rev as hard as my 88 crf honda engine,I've noticed that the cdi unit has 5 wire's connected to it what are these wire's as i might try and use a takegawa rev box on the ttr as that also use's 5 wire's to the rev box ,ADVICE PLEASE on the wiring of the cdi unit and the takegawa rev box......
    smoothoperatorsfreestyle's Avatar
    Jan 2007
    So-Tex
    Re: Timing A Ttr 50
    that's a sweet bike
    Joeybags919's Avatar
    Jan 2007
    Imlay City Michigan
    Re: Timing A Ttr 50
    they don't make any rev limmeter so I don't think that you are over reving it. or hitting the rev limmeter.
    how dose the plug look.
    if you are over fueling it the hole plug will be black it sounds like you are getting to much fuel.
    maybe checkthis site out to help you get it jetted a little better
    http://www.dansmc.com/Spark_Plugs/10.html
    justin_l_'s Avatar
    Jan 2007
    Southern Maine
    Re: Timing A Ttr 50
    I have an 88 kit and have NEVER hit revlimiter, so with that said, I think there is something else wrong with your bike. I have never tried to wire up a tak cdi box or any other box. The yamaha manual may give you a vague diagram on what the wires going into the stock box are, maybe you can figure it out, but my guess is that they are completely different, or else aftermarket companies would have come up with a pigtale adapter by now.
    Jan 2007
    Imlay City Michigan
    Re: Timing A Ttr 50
    have you check your valve clearence maybe they are too loose.. so the valves are staying open too long and floating.
    is getting old.!!!!
    Oct 2006
    south wales..uk
    Re: Timing A Ttr 50
    valves are ok and im running a 85 main jet and the needle is in the middle position and air screw is set to 1 and a quarter turns out..the kit came with a 90 and a 92 main jet and it was misfiring at the high end of the rev range with these fitted so i dropped it down to an 85 main jet and it revs clean but it rev's like it's hitting the limiter at high rev's..i'll get a new plug tomorrow and i'll run it for 20 mins to see what the colour is like and if it's black i'll try and find a smaller jet or might change the carb for a 20mm and jet that down and try it...
    Jan 2007
    Imlay City Michigan
    Re: Timing A Ttr 50
    what carb is in it?
    is getting old.!!!!
    Oct 2006
    south wales..uk
    Re: Timing A Ttr 50
    18MM carb that come's with the two brothers takegawa 107 kit...
  10. #9
    Jan 2007
    Imlay City Michigan
    Re: Timing A Ttr 50
    Man IDK... try smaller jets...
2007 yamaha ttr50 timing
how to set timing on a ttr 50
how to set timing on ttr 50
how to time a ttr 50
timing on a ttr50
ttr 50 rev box
ttr 50 timing
ttr 50 timing marks
ttr50 timing
ttr50 timing marks
yamaha ttr 50 timing
yamaha ttr50 timing marks
