Yoshimura TM-MJN24 Carb
This is a discussion on Yoshimura TM-MJN24 Carb within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Has anyone on here run one of the "Yoshi" carbs yet and what's your experience? In comparison to the Mikuni's, what's different and which do ...
Page 1 of 8 123 ... LastLast
Results 1 to 15 of 117
Like Tree1Likes
Thread: Yoshimura TM-MJN24 Carb
    HymieP's Avatar
    May 2008
    Norman, OK
    Has anyone on here run one of the "Yoshi" carbs yet and what's your experience? In comparison to the Mikuni's, what's different and which do you prefer? Thanks
    is what mini?
    reynolds_brad's Avatar
    Dec 2003
    San Francisco, CA
    Re: Yoshimura TM-MJN24 Carb
    Hands Down the best damn carbs ive ever worked with.
    Im running a Yosh MJN-TM24 on my 95cc motor and a MJN-TM26 on my 115 ape.
    I posted a thread a while back with my experiences with them. I think TMAS has one of these carbs now as well.
    The MJN design places small holes along the sides of the hollow needle to atomize fuel at the center of the carburator throat which is the point of highest intake velocity. This provides improved throttle response and horsepower at low and mid-range rpm. Peak power is also higher because the main jet is allowed to flow more fuel with less restriction. The pilot circuit is stopped when the throttle is closed in order to prevent run-on which keeps the combustion chambers cleaner.
    the carb is also thermal transdusive coated inside and out to reduce heat.
    pecore nere ufficiose
    Hidden Content
    p3racer's Avatar
    Sep 2003
    FLORIDA
    absolutly THE best performing carbs hands down. Easy to tune and make great power. I run a 24mm a 26mm and have a 24mm bored out to a 28mm and they all work perfect. Well worth the money.
    is Trying to have alittle fun in
    life!
    Grafixxs's Avatar
    Apr 2007
    Marshall,MI
    So now the question is, where to get one of these carbs? I assume the 24mm will work great on a 88cc as well?
    HymieP's Avatar
    May 2008
    Norman, OK
    Thanks, I think I'm going to go with the G-Craft intake with the swivel also. Pics would be great if you have them. Thanks
    HymieP's Avatar
    May 2008
    Norman, OK
    They say they work great on anything over 88cc. I'm still learning everything I can about these, but so far, they sound like "the" carb to run. Easily tuned which is what I am after.
    p3racer's Avatar
    Sep 2003
    FLORIDA
    Quote Originally Posted by Grafixxs
    MotoShopZ can get them I believe. Or Yoshimura
    sales@motoshopz.com
    is what mini?
    Dec 2003
    San Francisco, CA
    Quote Originally Posted by HymieP
    Here are two pics of the billet swivel intake.
    Hidden Content
  10. #9
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    i'v never seen a yoshi carb. can some one post pics.
  11. #10
    bwise's Avatar
    Dec 2008
    Atlantic Beach, FL
    Quote Originally Posted by cdoublejj
    its in the pics above your post.
  12. #11
    muxster's Avatar
    Sep 2008
    Redondo Beach, Ca.
    Here...get the rad wallpaper from Yoshi...
    http://www.yoshimura-jp.com/en/produ...onkey_1280.jpg
  13. #12
    Banned
    HACKMUNCH's Avatar
    Apr 2006
    BRUNSWICK OHIO
    So those are just tm mikuni flat slides with different needles?
  14. #13
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    yeah a mikuni yoshi the on on top says mikuni Tm26 it doesn't say yoshi on it?????
  15. #14
    shawnbassett26's Avatar
    Feb 2008
    Orlando FL
    Man that swivel is sweet.
    ~Shawn
  16. #15
    is Cruisin'
    Adam z50+R's Avatar
    Sep 2008
    Nuneaton, England
    i was looking at these carbs also
    i currently use a mikuni vm28 flatslider on my honda nice motor
    (180cc daytona dohc)
    i was looking at this carb mjn tmr 28 flatslider its so trick!
    it also has an accelerator pump !?
    what benefit would i have with this
    cheers
    adam
    Attached Images Attached Images
carburetor lc135
carburetor tm
carburetor yoshimura 135lc
kaberator yamaha lc
tm mjn 28mm
yoshimura 26mm carb
yoshimura carb
yoshimura carbs
yoshimura carburetor
yoshimura crab lc135
yoshimura mikuni tm-mjn series
