Need advice on replacing (Synapse) fork seals
This is a discussion on Need advice on replacing (Synapse) fork seals within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I have a CT70 with a set of 30mm Synapse fork legs. (These are copies of the Honda NSR50 fork legs.) There is some cracking ...
Results 1 to 10 of 10
    Branyers's Avatar
    Jul 2006
    Quincy, IL
    I have a CT70 with a set of 30mm Synapse fork legs. (These are copies of the Honda NSR50 fork legs.) There is some cracking going on in the seals, so I want to change them out.
    First I need to know if OEM Honda NSR50 seals are a direct replacement. I have no reason to believe otherwise, but just wanted to check and see if anyone could confirm this.
    Second, I am hoping to get some advice with changing the seals on NSR fork legs. It looks like the insides will just slide out with the removal of the bottom 8mm bolt. Could it be that easy?
    Thanks for any advice you can give.
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    Re: Need advice on replacing (Synapse) fork seals
    Yup. When I had my Synapse forks plated I replaced the seals with OEM Honda seals. They do come apart with just the removal of the damping rod bolt at the bottom also.
    The older I get, the faster I was !
    Branyers's Avatar
    Jul 2006
    Quincy, IL
    Thank you very much sir. That's all I needed to know. Looks like I got myself a little winter project ahead of me. Damn, I hate taking forks off...
    Branyers's Avatar
    Jul 2006
    Quincy, IL
    Holy hell! Changing fork seals is an SOB! Getting the old seals out entailed much cussing. Getting the new ones in isn't much better. Of course I damaged one of the seals in the process and have to order another one. Never want to do this job again!
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    Ummmm. Changing fork seals on a Gold Wing is an SOB...Changing fork seals on a minibike is a POC. ...I should have mentioned a little heat works wonders for this job.
    Branyers's Avatar
    Jul 2006
    Quincy, IL
    This might be a stupid question, but how do I apply heat without messing up the paint finish? Do you use a torch or stick 'em in the oven?
    is Moderator in training?
    s_10onbagz's Avatar
    Sep 2007
    Connecticut.
    Torch, just don't stay in one spot. You know the dust seals are easily replaced without changing the fork seals right?
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    A heat gun works good too.
  10. #9
    Branyers's Avatar
    Jul 2006
    Quincy, IL
    Quote Originally Posted by s_10onbagz
    When I bought new seals, they came as a set, with a dust seal and inner seal. So I figured while I had the forks apart, might as well change both. But I didn't realize what a pain it was gonna be until it was a little too late. When it comes time to do the seals on my NSR, I will more than likely follow your advice and just replace the dust seals. Those pop right out.
  11. #10
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    Off topis: Does anyone know the honda part number of the of the O-ring under/around the plug on top of the inner nsr leg?
    edit: found my answer in the nsr/nsf threads under technical resources.
changing the fork tube seals in a 1982 honda ct70
ct70 fork seals
honda nsr 50 fork seal
how to change fork seals on z50
how to replace fork seals honda ct 70
nsr50 forks disassembly
replacing fork seals ct70
synapse 30mm nsr forks
synapse forks nsr 50
synapse nsr style 30mm forks
