Fork Oil?
Fork Oil?
This is a discussion on Fork Oil? within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; What type, weight, oil goes in???...
Results 1 to 11 of 11
Thread: Fork Oil?
    zekeboy's Avatar
    Sep 2008
    The Island of Guam
    superdave308's Avatar
    May 2011
    Texas
    Im 200lbs, and like a little heavier fork oil, so I run Maxima 20wt. How much do you weigh and what kind of riding are you planning on doing?
    zekeboy's Avatar
    Sep 2008
    The Island of Guam
    Quote Originally Posted by superdave308 View Post
    I'm 185lbs and just street riding, nothing crazy cause the bike is lowered.
    zekeboy's Avatar
    Sep 2008
    The Island of Guam
    Quote Originally Posted by zekeboy View Post
    How much oil per fork goes in?
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    What forks do you have? ZB50 uses trans fluid. Budget and it works good.
    Ride on the edge
    zekeboy's Avatar
    Sep 2008
    The Island of Guam
    z50
    gbunner's Avatar
    Sep 2008
    Greensburg, Pa.
    z50
    There is no oil in z50 or even the newer crf50 forks. Just a spring and bushings.
    ph0b0s's Avatar
    Sep 2010
    Brisbane, Australia
    I've seen some pics where people grease the springs but not sure if they pack it with grease or just lube the springs
  10. #9
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    lube(grease) the bushings.
  11. #10
    monkeybikeguam's Avatar
    Mar 2008
    Guam USA
    He has aftermarket chinese forks with disc brakes that came off a monkey
  12. #11
    is Motos
    wondermuscle's Avatar
    Jun 2011
    San Diego
    Quote Originally Posted by monkeybikeguam View Post
    I run 5wt Maxima in one and 7wt Maxima in the other. With 5wt in both it is a bit soft under hard braking but great for cruisin''. 5wt and 7wt is a great compromise. I run the oil level just above the top valve.
china fork oil z50 clone
fork oil ct70
mini bike fork oil
planet minis fork oil
should i run maxima 5wt or 7wt
ssr 160r fork oil
which fork oil weight z50a
z50 fork lube
z50 fork oil
z50 fork oil specs
z50a fork grease
z50a fork oil or grease
