1980 Z50R Mild Revamp
This is a discussion on 1980 Z50R Mild Revamp within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I think you should use black stickers so that it is just a small amount of yellow around the outside. Should look awesome that way. ...
Page 7 of 9 FirstFirst ... 5 6 7 8 9 LastLast
Results 121 to 140 of 168
  1. #121
    is needing funding for parts...
    and whiskey.
    Brodie's Avatar
    Mar 2012
    Gold Coast, Australia
    I think you should use black stickers so that it is just a small amount of yellow around the outside. Should look awesome that way. Ohh and I would blacken the back of the front plate as well but that is just me. Keep us updated!
    1969 Honda Z50A K1, Restoration project begun 06.March.2012 Rebuilt 24.March.2012 Improvements Ongoing
    Z50A Replica Cafe Racer
    , Planning begun 10.April.2012 Building Began 01.May.2012 Powder Coat and fine tuning to go.
    Jincheng JC150Y, Revival attempt begun 1.September.2012 Got Bored, Given Up For Now.
    Deckson Daredevil, Partial restoration begun 3.January.2013
  2. #122
    is ............................
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Got it all back together and gassed her up. She started right up and purred like the little mouse she is. All thats left now is to get some black backgrounds for the number plates, adjust the chain and ride the piss out of it.
    I will get some better pics later... maybe...
  3. #123
    is distracted by minis
    bronco bobby's Avatar
    Dec 2011
    Hemet California
    Turned out nice
  4. #124
    is Go small or go home.
    ashz50r's Avatar
    May 2008
    Cornwall, UK
    Props my man, that looks frickin' awesome! I must get a new seat for mine while their still available. You got the mini bug?!
  5. #125
    jets76's Avatar
    Apr 2012
    I like it.
  6. #126
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Thanks fellas.
    Yeah, I got bit by the bug bad. Really bad.
  7. #127
    and whiskey.
    Brodie's Avatar
    Mar 2012
    Looks awesome. It will look even better once you get those stickers in place. Any plans for it motor/suspension wise?
  8. #128
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Quote Originally Posted by Brodie View Post
    Thanks brodie.
    I would like to do something with the motor in the future, but for now I will be keeping it stock and just have fun with it the way it is. Its slows a hell, but its still fun.
    As far as suspension goes, I installed heavy duty fork springs in it from fast50's and bolted up heavier sprung 280mm rear shocks. From the ten minutes I have rode it around the yard it seemed to be way better than the worn out stock stuff was.
    I would maybe consider a slightly longer swinger in the future, but I really want to keep it mostly stock and MINI.
  9. #129
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Welp, the Z was good to me all summer long. Winter is not far away and I'm itching to tinker again.
    Anyone have any luck with the cheap Chinese bolt in motors? I want more power and speed, but of course don't have the cash or experience to be rebuilding the stocker with bigger parts.
    Any suggestions? First hand experiences?
  10. #130
    and whiskey.
    Brodie's Avatar
    Mar 2012
    The Z160HO I have is crazy. I had to modify the frame a little to get the clutch basket to fit right. A friend of mine has a YX140 and that engine has gone hard for quite a while.
    How much power are you looking to get out of it?
  11. #131
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Well, I want it to be safe/useable power. My plan is to keep the bike mini (no big suspension/brake upgrades... well... at least thats the plan), so I was thinking one of those 110's or even 90's would probably be fine. I just want some more get up and go... and some more top end. I saw that 140 and it caught my eye, but is that too much power? A screamer would be sweet, but is it too much? I want something I can simply bolt in. No notching the frame and raising the tank and stuff like that.
    Also, do those cheap ($300) motors come with everything needed like they say? That just seems soooo cheap. Also, would I need a new exhaust?
    Thanks! I got some researching to do!!!
  12. #132
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    So, this motor from T-bolt *Piranha 140cc Engine fits Pit Bikes and other Minis - Engines - Piranha Engines - WHS-1143 - TBolt USA, LLC I can buy and just slip right in? And the carb, is it worth upgrading to the 26mm one, or is the 22 it comes with work well enough?
  13. #133
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    And dosnt that motor have a clutch? I dont see anything in the parts list that it comes with a cable/lever, but nothing in the "needed" list either....
  14. #134
    Gmbond's Avatar
    Sep 2012
    Ontario - Canada
    yes the piranha is a manual clutch - tbolt sells the cable and parts needed ask vince
    i've got a 4 speed manual lifan 125 in my 91 Z50 and its TONS of power for a wee lil bike ...... tough to hill climb, but a blast to ride and it freight trains away from my buddies 88 kit and 88 race head kitted bikes. ... i just need more gearing for the speed it wants to pull
    if you are trail riding the snowblower tires are nice too
  15. #135
    is No Status
    MisterGraphic's Avatar
    Aug 2012
    New-Brunswick (Canada)
    Did you end up finalizing the stickers?
    Here's a random preview....
    Stock 1972 CT70, 1500 miles, slowly being cleaned-up
  16. #136
    and whiskey.
    Brodie's Avatar
    Mar 2012
    I would say a 125 will do you well. I have a Lifan 125 in my '82R and it is a tight squeeze for the carby to fit. If I had a different manifold it would be fine.
    Being that the 125 I have is a zombie engine (was dead for a long time and I brought it back to life some how) it has plenty enough power for a fun bike.
    Once you start looking at things like 140 and up it gets into the wheelie on gear change stage and some of the run around fun goes away.
    As for that piranha engine the manifold on that looks like it should fit under the tank without you having to raise it. I would stick with the 22mm carby if you are going to use the stock exhaust.
    I have a 26mm on my 160 and and high flow exhaust to match.
  17. #137
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Quote Originally Posted by Gmbond View Post
    Thanks for the info! Yeah, when I do the motor upgrade I will for sure be upgrading the tires. I was thinking those oversized stock looking ones would be ok, but for some reason the thoughts of the snowblower tires keep overpowering them.
    Quote Originally Posted by MisterGraphic View Post
    Hahahaha, that dosnt look too bad! You must have some serious computer skills to whip that out.
    Most of the summer I had just a black background on the plate (with the outer yellow ring showing) and for some reason it just didnt work for me. So I peeled them off and have been running just the yellow. Thats got me thinking though!!!!
    I was checking the project you have going on earlier. Good luck with that, looking good so far!
    If you ever get that vinyl computer printer/cutter setup, I can be the test mule and you could whip me out some backgrounds for my number plates!!!!
    Thanks for the info Brodie. Yeah, the 140 seemed like it would be just a bit big for a fun everyday cruiser. While it would be fun to RIP IT, I still want to be able to cruise too.
    So the stock exhaust would work ok with a new motor? Obviously a high performance one would be better, but if it will run ok with the stocker than I am all for saving some cash.
  18. #138
    and whiskey.
    Brodie's Avatar
    Mar 2012
    It would run ok with the stock exhaust but the flow will be restricted. That is why the 22mm carby would be better, less intake as the exhaust is restricted. When you take the exhaust out just give it a good clean and see if you can smooth up any areas to help with flow. I am not sure there is anything that can be removed from the muffler to help but someone else might know. Will be interesting to see what you decide. Also I believe you can get semi-auto 125 if you are still after that.
  19. #139
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Im thinking I should keep it at 125 or less. Probably end up going the 125 route though. I just dont want to be mad that I didnt go with the 140. But I think you have pretty much justified to not go that big for my intended use.
    As far as manual or semi, I am still torn. I think a clutch would be bitchin, but at the same time I am pondering about the times I putt around in the yard and woods with my son, where a semi auto would be way better. Hmmmmmmmm. I have a lot of time to think about it. But right now I am thinking clutch. I wonder if the clutches hold up well on these things?
  20. #140
    is No Status
    Aug 2012
    Haha, no problem!
    Roland (printer supplier) never got back to me with more information
    so I put that aside for a few months. (I should follow-up with them...)
    Your bike looks good! bet it's a blast to ride
1980 z50
1980 z50r
dohc z50
honda 50 r fenders
honda z50 steering stop
planet minis
z 50
z 50 r
z50 number plate
z50 side cover
z50r
z50r 1980
