Stuck on my 1980 Z50R build
This is a discussion on Stuck on my 1980 Z50R build within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Greetings, I'm rebuilding my 1980 Z50R and having some problems with getting it to start. The 1980 had a bad engine that I was going ...
Results 1 to 4 of 4
    85blazer's Avatar
    Jul 2008
    Greetings,
    The 1980 had a bad engine that I was going to try and rebuild until I saw a 1979 Z50R on CL 100 miles away in Georiga.
    So I did the correct thing and cut out early from work for a 200 mile road trip.Well the one pick on CL was bad and this thing was in BAD shape.It was running but held together with clay and bailing wire.After a short ride with no brakes I decided the few good parts Tank,engine/trans,4 lug rims was worth 200 bucks to me and we made a deal.As we are loading it in my truck he tells me how to mix the gas with oil 50:1....WTF!
    So,when I get back home I just swap the tank with the one from my 1986 with fresh gas, install the correct NGK plug and she starts right up.I rode it around the yard a few times until I almost took out my fence with no brakes and decided the engine was good.
    Fast forward a few weeks and my parts came in so I pulled the motor from the 79 and put it on my 1980 frame.
    The only thing that wouldn't bold right on was the factory muff from the 79 or the 80;it is about 1/4 to 1/2" off from the frame.
    Are the 79 and 80 49cc honda engines the same?
    I used all the same wires and coil with the 79 engine that ran fine a week ago and now the POS wont start!
    The only thing I can think of is I must have the carb messed up after I replaced all the cables.
    The throtle doesn't feel the same as it did before so I am starting there after lunch today.
    Sorry for the wall of text,any thoughts?
    85blazer's Avatar
    Jul 2008
    Well I got her going and after some tinkering she is running pretty good.
    It smokes a little but shifts great and I like the way it is looking.
    Is there anything starter fluid can't fix?
    I need to figure out what the problem is with my new throttle cable,or how to put it together correct.
    The spring in the top of the carb seemed to be to long or the cable is to short;I took the spring out and it ran fine.
    Here is a pic of the 1980 I went a little crazy with the fleck in the paint.
    is lurking
    olyelr's Avatar
    Dec 2011
    Kewadin, MI
    Nice little runner.
    Where did ya get the handlebar/clamp setup? If that is an '80, it should have had fixed bars with no clamps.
    85blazer's Avatar
    Jul 2008
    Quote Originally Posted by olyelr View Post
    Nice little runner.
    The 1980 did have fixed bars but I was able to salvage the clamps that came with the 1979.
    I'm not sure if the clamps from the 79 are factory or not.
  1. 1980 Z50R Build
    By z50r racer in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-28-2009, 06:41 PM
  2. Need a 1980 Z50R rear hub
    By carnut226 in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 06-09-2009, 07:47 PM
  3. 1980 Z50r $350
    By Outlaw Powersports in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-27-2006, 12:28 AM
  4. Who's parting out a 1980's Z50R?
    By d0n in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-20-2006, 12:45 PM
  5. 1980 Z50r parts
    By RazBarlow in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 01-28-2006, 08:46 AM
1979 honda z50 troubleshooting
1979 z50 wont start
1980 honda z50r throttle cable diagram
1980 honda z50r wont start
1980 z50r
1980 z50r carb
1980 z50r wont start
honda z50 throttle sticking
honda z50r throttle cable problem
how to replace throttle cabe honda z50
z50r build
z50r carb
