dampened rear sprocket for monkey 3-bolt
This is a discussion on dampened rear sprocket for monkey 3-bolt within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Just curious, but does any manufacturer make a dampened sprocket compatible with 420 chain? I know shift-up makes one for 415 chain, but I need ...
Results 1 to 7 of 7
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Just curious, but does any manufacturer make a dampened sprocket compatible with 420 chain? I know shift-up makes one for 415 chain, but I need one for 420. Anybody know if these are available? this is for a monkey hub, 3 bolt.
    is awesome
    mattmofob's Avatar
    Oct 2008
    Rochester, NY
    Takegawa makes a cush drive that accepts standard sprockets. costs $250.
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    What matt says.
    Have a tak dampened monkeyhub for drumbrake lying around at home waiting to be build in. (It is freezing overhere, so i am in no hurry.)
    edit: takegawa
    06-08-0045
    SP TAKEGAWA : Rear Drum brake for Damper hubKit [06-08-0045]
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Naw...that won't work. I have sold wheels with the hubs already built into them. On my other bike, I have the g'craft version of the dampened hub...it works great. However, that's not an option for me on this hub. So I still need just a dampened sprocket.
    nielspbr's Avatar
    Feb 2008
    You know that the only difference between 420(1/4") and 415(3/16") chaindrives is the thickness of the sprocket?
    Source: REGINA CHAIN - Product data sheet
    edit: The hybrid driven sprocket, they have a xr50/100 ape nsf100 version as well, still 415 size though. Strange for a 100 version you would expect 420 (or maybe even 42
    ALIKA T3's Avatar
    Oct 2011
    HONOLULU
    Pardon my ignorance,but the sprocket determines the type of chain right? Can't you mount a 420 sprocket on this Takegawa hub?
    What is the advantage of running such part?
    Thanks!
  7. #7
    nielspbr's Avatar
    Feb 2008
    Fatcaat has wheels with build in hubs, so the takegawa hub is obsolete.
  1. M60 bolt pattern? Is this the KTM 65 rear sprocket pattern?
    By crazygoat in forum KLX110, DRZ110, TTR90
    Last Post: 08-23-2010, 05:41 PM
  2. WTB- stock klx110 swinger bolt/ nut and rear axle bolt/ nut
    By jedsled in forum Bikes and Parts Wanted - All Makes
    Last Post: 05-05-2009, 09:05 PM
  3. z50r stock length oil dampened forks
    By kxfracer108 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-26-2008, 06:49 PM
  4. WTB: Z50 32T 3-Bolt Rear/Drive Sprocket
    By symp in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 03-14-2007, 03:26 AM
  5. WTB-rear sprocket bolt/brake rod/throttle cable
    By SKIPPY_F7 in forum CRF50/CRF70 Parts For Sale
    Last Post: 07-25-2006, 05:47 PM
3 bolt mini bike rear sprocket
3 bolt mini bike sprocket
415 chain for honda z50
ct 70 3 bolt rear hub
difference between 415 and 420 chain
honda z50 rear sprocket
honda z50 rear sprocket bolts
ktm racer 415 planet minis
mini bike sprocket 3 bolt
standard ct70 sprockets
z50 23t rear sprocket
z50 rear sprocket dampener
