z50 leaking gas out of carb
This is a discussion on z50 leaking gas out of carb within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Well, I have a problem with my z50. It's leaking gas out of the carb drain line. When ever I shut it off, or it's ...
Results 1 to 4 of 4
    2stroked's Avatar
    Sep 2011
    NC
    Well, I have a problem with my z50. It's leaking gas out of the carb drain line. When ever I shut it off, or it's idling gas is dribbling out of the carb drain line. I can't use it like this, and i really need to figure out what's up with it. The drain screw is tight and seems okay. Any guesses?
    is Rocking a 88cc DOHC on 8's
    eichkay's Avatar
    Jul 2005
    Perth, Australia
    Quote Originally Posted by 2stroked View Post
    You'll find there is some dirt or something in the float needles seat , clean the carbi out and your problem will be solved
    20plus
    Fifty Riders
    Dreamcrusher67's Avatar
    Aug 2011
    Central Valley, Ca.
    Quote Originally Posted by eichkay View Post
    Yea yea, most likely what eichkay says but ive had the pin/ nipple thing on the end of the float needle stuck in before. Either way, if it isnt the float sticking or the O ring on the bowl drain its that float needle.
    2stroked's Avatar
    Sep 2011
    NC
    Ok thanks.
  1. Leaking Carb
    By mdwaller in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-04-2009, 11:30 PM
  2. just got a KLX and its leaking gas from the carb
    By nugent_crai in forum Roost Area
    Last Post: 11-14-2008, 02:38 PM
  3. carb leaking? need help
    By Slowfiddy19 in forum CRF50
    Last Post: 10-12-2008, 08:37 AM
  4. help leaking carb
    By shegg65 in forum Chinese/Import Minis - General Discussion
    Last Post: 09-14-2008, 12:05 AM
  5. Carb Leaking Gas
    By KCL in forum Chinese/Import Minis - General Discussion
    Last Post: 01-14-2007, 12:10 AM
carburetor leaking on honda trail 70
ct70 carb leaking from drain
ct70 carburetor leaking
honda ct70 carburetor l eaking
honda z50 leaking gas
honda z50 leaking gas out of overflow when sitting
honda z50r leaking fuel out of carby
my suzuiki z 50 is leaking gas help
suzuki z50 carburetor draining
z50 carb float
z50 leaks gas
z50r carby leak
