honda z50 1973 minitrail restoration! need tips and guildlines
This is a discussion on honda z50 1973 minitrail restoration! need tips and guildlines within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; hey guys im new to the forum!i love working in mechanic, i decided to restore this little minibike because it had been in the family ...
03-10-2012 05:27 PM
GREAT lookss like all the spaces between every paragraph they were not inserted or somthing!also is it possible to add a fourth gear in the tranny? stock theres 3
ahh i just saw the edit button didnt see it before
FIXED
Originally Posted by
Big Will The Junior
Yes. The ATC 70 & TRX 70 4 speed transmissions will work but you have to split the cases.
Here is a few pics of my 1973 which I sold.
1973 Z50A K4
1973 Z50A K4
thanks alot, looks pretty nice, is both sites that i reffered too are good? do you know other sites and can you show me a site were i can get these gears?
also is there any guides to install them and do you feel a good differance?
thanks alot this project is going to be a blast
TboltUSA carys a 4speed kit for 150. if your going to split the cases I grab a stroker crank and connecting rod on the piston you can go to 88cc giving you 110cc if combined with the stroker kit. and a (xr70 crf70 ct70) head will give you larger valves. or a tb race head will go even bigger on the valves. You could throw in a high volume oil pump as well and some extra stiff valve springs if you intend to run a mild race or race cam.
Just some ideas, there is always more you can do like manual clutch kits
and for the bike itself there are lots of 10" and 12" rims to choose from that fit the 50 hubs you already have
a xr70 swinger will give you room for the 10's
TBoltUSA is a forum member of this site and offer good customer support. I recently bought a GPX140 china motor from them. i got it and noticed my cdi was missing and kick starter was the wrong size. I contacted tbolts support via email and a week later I had a new kicker wireharness and cdi unit free of charge and everything works great now.
Basicly Tbolt fixed what china messed up.
Big Will The Junior
Yes both sites are good.You would have to find the Honda four speed transmission on ebay or off a PM member. The extra gear does make a difference.There are free online manuals and youtube videos that would help you through the installation.
1985 HONDA ATC70 ATC 70 TRANSMISSION GEARS TRANS SHIFT DRUM FORKS ENGINE MOTOR | eBay
thanks alot! i will think about the 4th gear kit does it give much more top speed i want to go around 70-80 km-h. if i were to open the case i dont want to buy another crank shaft because i am already spending alot of money on it, but will the stock one be strong enough to not break? also i need to change my rims, do i really need to change the swinger in the back for a longer one for 10 inch rims? also i am really looking forward to this kit! Honda Trail Bikes my only concern is like i said the the crank shaft if it will be tough enought and if the head is assemble like in the picture so i just have to install the piston on the crank shaft, then put the piston rings ect, because it looks very complex to install the valve and everything in a 4 stroke head.
thanks alot!
EDIT: i found the edit button so now the thread is better its neater on top
The stock crank is ok for the kit you want. Pretty easy install. He is a link to a speed calculator that will help you get to 70-80 km.
Honda50.com Gear Ratio - Speed Calculator
thanks,
but i rather just base it on peoples experiences with their bike, do you think with this kit i will acheive 70-80 km-h?
thank you
Big Will The Junior
thanks,
thank you
Yes, but you can also play around with the front and back sprocket sizes to get to 80 km.
ok, and about the stock pipe on the 88cc kit will it be ok? and does it say 88cc on the engine?
thanks
edit: also i saw your mini trail that you sold, the stand that you installed did u have to do modification or it fitted bolt on? the stand on the side
i almost forgot, do i need an http://tboltusa.com/store/trail-bike...ls-p-1380.html high volume oil pump? is it worth it?
Big Will The Junior
Get a better pipe for more gains. Get the oil pump too. A must. It does not say 88cc on the barrel.
Honda Trail Bikes
ok great, and what about this kit is it comparable to the 88cc big bore? Kitaco 75cc Big Bore Kit for Z50 - Classic Honda - Pit Bike Parts
Big Will The Junior
Debatable topic. Both are good. Maybe others will voice their opinion.
ok thanks so it will be vs the 88cc kit with the 20mm carb and the racing head and cam vs that 75cc big bore with stock head and stock carb and stock cam,
becaus the 88cc is very expensive and i need to get the extra oil pump too so people give me your oppinions
Maybe think about getting a cam instead of stock.
Honda Trail Bikes
Subscribed, Looks to be an interesting build!
- You may not post replies
- You may not edit your posts
Forum Rules
By infidel in forum Z50, CT70 and JDM Monkeybikes
Last Post: 04-16-2008, 04:25 PM
By lumpdog256 in forum Z50, CT70, ZB50 and other Honda Parts
Last Post: 11-03-2007, 08:41 PM
By fatcaaat in forum Complete Bikes For Sale - All makes and models
Last Post: 07-30-2007, 03:26 PM
By fatcaaat in forum Z50, CT70, ZB50 and other Honda Parts
Last Post: 07-30-2007, 03:12 PM
By Dilligaf in forum Z50, CT70 and JDM Monkeybikes
Last Post: 02-27-2005, 08:29 PM
1973 honda mini trail 50
1973 honda z50
1973 honda z50 parts
honda mini trail
honda mini trail 50 parts
honda mini trail forum
honda mini trail forums
honda mini trail restoration
honda z50
honda z50 mini trail restoration
honda z50 restoration
how to restore a honda z50
Tags for this Thread
