Ct 70 88cc build questions
This is a discussion on Ct 70 88cc build questions within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I purchased the 88cc big bore kit and my delema is with the carb installation.
The overflow seems to close to the cylinder.
The kit ...
The kit came with the 20mm carb, intake and phenolic spacer.
Im unsure of the order of the phenolic spacer installation, or what to do about the float bowl overflow.
No instructions were sold with this kit.
04-23-2012 12:19 AM
Is the pastic spacer mounted upside down?
I whould think the tab has to be between the cooling fins and the float bowl to prevent heat radiation heating up the bowl.
The heatstop is installed correctly in the pictures, flipping it over will result in the float bowl drain hitting it and breaking it off when tightening the mounting bolts to the head. I have filed the drain tip down a little and at a 45 degree angle, to lessen the angle of the drain hose when installed in place. You have everything in place correctly.
Errrr <cough> that thingy is supposed to go vertically between carb and intake and NOT horizontally between intake and head
Originally Posted by
dirtbkr188
Thanks, everything you said makes sense.
The project moves forward.
- You may not post replies
- You may not edit your posts
Forum Rules
Last Post: 10-26-2010, 10:56 PM
By yernkie in forum CRF50
Last Post: 05-02-2010, 03:03 PM
By bigmase840 in forum Chinese/Import Minis - General Discussion
Last Post: 01-11-2010, 06:04 PM
By 76roller in forum CRF50
Last Post: 07-04-2009, 04:40 PM
By froggie3kb in forum CRF50
Last Post: 01-31-2008, 09:27 AM
88cc kit ct 70 instructions
best 88cc kit for ct70
bigger carborator for ct 70
ct70 88 kit
ct70 88 kit install
ct70 88cc big bore build
ct70 88cc kit
ct70 big bore kit
honda 70 88cc big bore build
honda ct70 88cc
honda ct70 big bore build
how to install 88cc bore kit
