z50 year and light questions
This is a discussion on z50 year and light questions within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; i just got this z50 a couple days ago and i was just wondering if any of you guys can tell me what year the ...
Results 1 to 19 of 19
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    i just got this z50 a couple days ago and i was just wondering if any of you guys can tell me what year the bike is and i was wondering do you have to have the little batterie to run the lights or can you have it running and they will be on because i think i need to fix some wiring but the brake light dont work when running but it works with a 9v batterie so i was just wondering. thanksClick image for larger version.
    is needing funding for parts...
    and whiskey.
    Brodie's Avatar
    Mar 2012
    Gold Coast, Australia
    Hard to tell from the picture but I am fairly sure that is a 70-71 K2. That is judging by the fenders anyway. If you could take a picture of the other side I could tell you.
    If it is a K2 they did not have a battery and the lights are 6v. It should also have a headlight. Also have a look here and use your frame number to check what year.
    Honda50.com Model Vin Decoder
    1969 Honda Z50A K1, Restoration project begun 06.March.2012 Rebuilt 24.March.2012 Improvements Ongoing
    Z50A Replica Cafe Racer
    , Planning begun 10.April.2012 Building Began 01.May.2012 Powder Coat and fine tuning to go.
    Jincheng JC150Y, Revival attempt begun 1.September.2012 Got Bored, Given Up For Now.
    Deckson Daredevil, Partial restoration begun 3.January.2013
    is Looking for Takegawa special
    clutch and CR 3speed for crf50
    davmo's Avatar
    Dec 2011
    Denton Texas little d.
    Quote Originally Posted by bfaith View Post
    I am betting on 69-70 K1, based on the tank and taillight bracket. Agree with Brodie, that might be a K2 rear fender, but the front fender looks to be neither K1 or K2. Also, you asked if you have to have the "little battery" which makes me think there must be a battery holder. To answer, no, you don't have to have a battery hooked up on a K1 to run the lights. There are other models like the CT70 and SL70 that require a battery to be there, or at least the part of the battery harness that has the ignition jump wire in it.
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    Ya it has a little battery holder under the seat and the head light is gone I no that can u just use a 12v head light or do u have to use a 6 volt. I was also thinking of useing a battery from one of those mini power wheel things because I can get one of those for like 20$ and there 6 volt
    davmo's Avatar
    Dec 2011
    Your engine if original, puts out 6volts. You would need the 6volt headlight. The sealed battery or "gel" battery is a good idea, and will work fine. You really only need the battery to keep your lights bright at low speeds, I don't have them in half my bikes, and it is OK, but there are times a little more light would be a good thing.
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by davmo View Post
    Thats actually not correct. These motor's put out 20+v when you get the RPM's up. It's all in the regulation of power. You can use a 12v regulator on there and run 12v lighting if you want. You can run a 6v regulator and run 12v bulbs...they will be dim. I would think that you'd fry a barbie truck battery pretty quick seeing it is going to get a continual dose of charging. You do not need a battery to run the lights...if properly setup, they will dim a little at idle, but will run bright completely without a battery. you can buy 6v and 12v regulators are dratv on the cheap.
  7. #7
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    K do u need the rectifier thing with the two plates of metal to run lights without the batterie because I don't want to use a battery if I don't have to
  8. #8
    SuzukiRider250's Avatar
    Dec 2011
    Grand Junction, CO
    I looked it up, and you don't need to use a battery. You can run the lights straight from the motor without any outside power source.
  9. #9
    davmo's Avatar
    Dec 2011
    Yeah, the gel batteries are pretty well tested in these bikes. More amps, stay charged longer, no acid drip. Lots of folks using them, and widely available from moto retailers. No disrespect, @ fatcaaat, but while technically incorrect, my advice is still the same: you need to go 6volt on your light with this stator. The peak voltage is good to know, but not relevant in the actual application. A 12volt regulator and lights with this stator would give you dim lighting most of the time. If you want the kind of wattage modern engines put out, then you need the rare earth magnet flywheels that have made that possible. As far as running without a rectifier or any voltage regulation, not a good idea. as fatcaaat stated: 20+V at high RPM. That pop is your bulbs frying. There are some retailers on this site (T-Bolt, Honda TB, to name a couple) with inexpensive rectifier repops, somewhere in the 12 dollar range. Good luck.
  10. #10
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    i no that but do u need the rectifier witch u probly dont no what that is lol
  11. #11
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    how much would you think a jell battery would cost and does the z50 some how charge the battery on the bike or do you need a charger to
  12. #12
    davmo's Avatar
    Dec 2011
    CHPminis.com sells one for about 15 bucks, but you could probably find one closer t where you live. At the CHP site, it is on the CT70 page, way down near the bottom of the page (they have one looong page.) Put the reproduction rectifier in the harness, hook up your battery, and it will need some charging if you don't ride it much, but most sealed batteries come charged. The thing you will get out of having a battery is that the back light/brake light will still work with the engine turned off, a safety feature. It also allows things like a horn to be used.
  13. #13
    is distracted by minis
    bronco bobby's Avatar
    Dec 2011
    Hemet California
    Since we are talking about rectifiers, what is the difference between a 2 wire and 4 wire, and say I wanted to light up a piranha yx140, would I need a 2 or 4?
  14. #14
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    NO battery needed": 6V_AC_REGULATOR FOR HI_OUTPUT_STATORS W/_AC_LIGHT_COILS (95Q) temp out of stock YOu can find them cheaper and similiar at other places. you could go 12v but you'd be very dim except at high RPM. I have a 69 z50. As an FYI, the standard setup for the original harness uses the battery as the sink so your bulbs don't pop. If you eliminate the battery, you def need a regulator like I show.
  15. #15
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    can you just wire the lights strate from the three wires that are from the ignition coils and points because i dont want to use a battery and i dont really care about a switch or any thing like that and i dont really care if there on durring the day. do i still need a rectifier or any thing like that. thanks
  16. #16
    and whiskey.
    Brodie's Avatar
    Mar 2012
    You will NEED a 6V Regulator to run 6V lighting. Most of them just T off the lighting wire from the stator.
  17. #17
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    what wire is the lighting wire like what color and how many volts comes from it at idle. thanks
  18. #18
    and whiskey.
    Brodie's Avatar
    Mar 2012
    I would not have a clue since my '69 has one wire coming from the stator. It could be yellow. Just test with a test light or multi meter to see which lights up while the bike is running. What colours do you have to choose from? As for voltage. no idea.
  19. #19
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    I am not sher they are kind of faded so I will just try the wires and see what has power for lights
  1. Brake light works and not tail light?????
    By aaron6920 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-16-2009, 03:31 AM
  2. Moto Town (maybe this year if not next year)
    By streetsquid101 in forum Master of Minis
    Last Post: 10-09-2008, 01:35 PM
  3. help with a light kit
    By fastRob in forum CRF50
    Last Post: 10-02-2008, 10:43 PM
  4. Wanted: Z50A K1 Tail Light bracket with Tail Light Assembly
    By 50ryder420 in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 05-02-2008, 01:19 PM
  5. klx questions from a 30 year old.
    By 2nd nature in forum KLX110, DRZ110, TTR90
    Last Post: 11-05-2007, 03:12 AM
6v regulator rectifier z50
does a 1977 z-50 have a battery
honda z50 light system
honda z50 sealed battery
honda z50 tail light
how to charge a battery honda z50
how to put light on z50
regulator z50 k2
what wire is used for lighting z50
will honda 50 start without a battery ? z50 k1
z50 lights
z50 regulator
