ignition cover/ ignition info needed
This is a discussion on ignition cover/ ignition info needed within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I am having trouble with my z50 ignition cover fitting,is there a different cover for early and later 6v ignitions? the only cover i have ...
Results 1 to 3 of 3
    jrotten's Avatar
    Jan 2007
    rainy washington
    Question ignition cover/ ignition info needed
    I am having trouble with my z50 ignition cover fitting,is there a different cover for early and later 6v ignitions? the only cover i have that clears the flywheel is off a late model china clone. Here's what i did to the engine,to clarify any questions- early engine cases-z50ae143453 {k1},84' crankshaft, 6volt points ignition off of a k1 engine, so did i not seat the flywheel correctly? or do i need an early ignition cover? i still have the complete igntion off of the 84' engine but saving for another engine,so i didn't think there was a problem using the k1 igntion on the 84' crank.Thanks for the help
    is just truckin' along...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    If you're using the K1 flywheel, it will not seat properly on the '84 crankshaft, due to a different crank taper. The K1 flywheel is not sliding all the way on. I'm not sure if the '84 flywheel will work properly with the K1 stator, either.
    - dirtbkr188 -
    jrotten's Avatar
    Jan 2007
    rainy washington
    Thanks for the info,that sounds logical.I didn't think there was early and late ignition covers.This is my first foray into mixing parts from different model years.I do have the complete flywheel and stator assy from the 84' i will swap out.thanks for the info
  1. K1 or K2 Z50 ignition switch info needed
    By chimp in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-27-2012, 07:14 PM
  2. Wtb Ignition Cover
    By Mx353 in forum Bikes and Parts Wanted - All Makes
    Last Post: 12-27-2011, 09:33 PM
  3. Ignition Cover Needed!!!
    By imoto228 in forum Bikes and Parts Wanted - All Makes
    Last Post: 09-26-2011, 03:20 PM
  4. Gasket Sets. Ignition, Clutch cover, Cam Cover, Tappet Cover..
    By Redheadracing in forum KLX110/Midsize Parts for Sale
    Last Post: 08-24-2010, 10:58 PM
  5. Where to buy cut ignition cover
    By xr100man in forum CRF50
    Last Post: 08-06-2007, 03:37 PM
2 different ct70 flywheel covers
crf50 ignition cover questions
ct70 flywheel cover
cut z50 ignition cover
will a crf 50 ignition cover fit a z50
will a crf50 ignition cover fit a z50?
