help me identify the year of this Ct70 i picked up over the weekend.
This is a discussion on help me identify the year of this Ct70 i picked up over the weekend. within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I know it's a K0, but i cant for the life of me find a manufacture date.. The Serial # reads ct70-100272 It being lower ...
Results 1 to 11 of 11
    JoshmuthaF's Avatar
    Dec 2003
    ohio
    I know it's a K0, but i cant for the life of me find a manufacture date.. The Serial # reads ct70-100272 It being lower numbers, I would think it is a 69? anyone have any insight? I'm likely going to restore it to it's original state the best i can.
    is in need of more ZB50's
    tmas's Avatar
    Apr 2005
    ...otnoroT...
    JoshmuthaF's Avatar
    Dec 2003
    ohio
    i've seen that, but that still only narrows it down to 69-71.
    tmas's Avatar
    Apr 2005
    ...otnoroT...
    If it's the original engine.......Maybe try checking the engine serial number? Hope this helps.
    Honda50.com Engine Vin Decoder
    blacufo's Avatar
    Nov 2011
    Nor Cal
    Your bike is a 1969 and likely a silver tag model, which are the more desirable ones. I have a 1969 with a build date of 09/69 with a frame serial number starting with 191xxx. Yours would have to be a early 69 with a frame number starting with 100xxx. If you have a look at the motor on the left side near where the shifter is, it should also have a number that is close to the same series of numbers. If is it close to the number on the frame its likley the original motor. Mine is off by about 80 between the motor and frame numbers.
    You can also have a look at the horn you have, see if the has screws or rivots on the housing shell, the early solver tags used screws.
    JoshmuthaF's Avatar
    Dec 2003
    ohio
    Thanks blacufo! The engine serial# reads ct70E 100342 , So it would appear it is likely orignal. The horn does have philps head screws instead of rivits. When you say Silver tag, are you refering to the tag on the head tube? Because it does have a silver label there. Where would i look for a manufacture date?
  7. #7
    blacufo's Avatar
    Nov 2011
    Nor Cal
    Silver tags like you have wont have a manufacturing date on tag, but they were from the first month of production which would have been August. I have an early Black tag 1969,( black tags they added the VIN and production date) which was built in 09/69 and still has the early parts like you have on yours. Based on the number on the frame and motor I would say you have a matching numbers bike, and most likley one that was made on the first or second day of production. Its safe to say your frame is probably the the first of 272 made based on the VIN and the motor is the first of 342 made for 69 CT70. Nice find
    Quote Originally Posted by JoshmuthaF View Post
  8. #8
    mikesbike's Avatar
    Mar 2012
    San Diego, Ca
    My vin reads
    CT70101861
    Registration says its a 1970 but the online chart its between 69-71
    is this the silver tag?
    and mine has screws on the horn
    dont have original engine with it
  9. #9
    blacufo's Avatar
    Nov 2011
    Nor Cal
    that is a silvertag ID, and this would be an early production 69 based on your production number. If your registration says 1970, then its likely when the bike was sold or actually registered with your DMV. I have another Ct that has a build date of 10/1971 but my title shows 1972.
    Quote Originally Posted by mikesbike View Post
    My vin reads
    CT70101861
  10. #10
    mikesbike's Avatar
    Mar 2012
    San Diego, Ca
    this is how I got it, also street legal with original license plate and newer plate
    added couple newer parts but other then that nothing else done
    how it looks now
    so you think the $1500 price was fair? even though it didnt come with original engine/exhaust
  11. #11
    blacufo's Avatar
    Nov 2011
    Nor Cal
    I think that is a fair price. Being that its a plated bike in California I would say bumps up the price vs one without a plate. If your gonna ride these on the streets the aftermarket motors are an inexpensive way to get them to perform on the street. To rebuild a stock 70 the right way to get it to pull a 200lbs rider around your will spend a few hundred bucks just on parts to do it right, not to mention labor if you cant. You can always keep an eye out for a motor out of Ct70 with a serial number close to what your frame number is. Nice bike
    how it looks now
  1. Picked up 81 CT70 today
    By bigmatthew46 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 04-01-2012, 10:06 PM
  2. Just picked up my first ct70
    By jsander9 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-25-2009, 03:32 PM
  3. Just got picked up by ssr for this year
    By chasetheface123 in forum Roost Area
    Last Post: 09-12-2009, 10:16 AM
  4. OGM SX140 WANT GONE ASAP! 800 picked up, this weekend only
    By kawasakicoby125 in forum Complete Bikes For Sale - All makes and models
    Last Post: 06-04-2009, 10:36 PM
  5. Picked up my new bike this weekend.
    By zman320 in forum Roost Area
    Last Post: 05-27-2009, 09:59 AM
ct70 frame and engine numbers
ct70 serial numbers
ct70 silver tag
honda ct 70
honda ct 70 serial numbers
honda ct70 copper tag
honda ct70 engine serial numbers
honda ct70 frame numbers
honda ct70 silver tag
honda ct70h serial numbers problems
honda trail 70 vin number
what is a silver tag honda ct70?
