I noticed my fly Wheel shaft does not have the guide on it to line up the Fly Wheel. Is the shaft broken? Can this piece be replaced? I'm talking about the raised section of the shaft where the groove of the Fly Wheel slides onto, thanks
This is a discussion on flywheel shaft question within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I noticed my fly Wheel shaft does not have the guide on it to line up the Fly Wheel. Is the shaft broken? Can this ...
#11 in the link. called the woodruff key
CRANKSHAFT Honda Z50R 1999 OEM Parts - Cheap Cycle Parts
Thanks! Got the z to run made it half way around the block before the flywheel came off, found the nut and washer but couldent find that piece anywhere day by day I'm getting one step closer
