CT70H KO Headlight dont work
This is a discussion on CT70H KO Headlight dont work within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Well this nice blue CT70H is done except the headlight has no power. The power comes from the ignition switch. The yellow stator wire goes ...
Results 1 to 3 of 3
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Well this nice blue CT70H is done except the headlight has no power. The power comes from the ignition switch. The yellow stator wire goes to the ignition switch to feed it power. The stator is a Hitachi and has a new CHP charging coil. Anyone have any idea what or how to test for this problem? The other wire end "green" from the charge coil goes to the rectifier.
    Ride on the edge
    bnsnacks's Avatar
    Jun 2012
    Quote Originally Posted by geezer
    Check the obvious are u sure the light is good do you have a good ground maybe check contact on the ignition switch itself . you know when the key is up for light to be on is it making good contact
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Not that anyone cares, but i fixed it. LOL Bad bulb. I was checking power to the bulb with my meter set on 6VDC the headlight circut on this bike runs on AC voltage. Thats what threw me off. I thought i had no power.
    Ride on the edge
  1. Bulb Work Around for 12v CT70 Headlight
    By muxster in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-30-2008, 12:28 PM
  2. AHH turn signals still dont work!!
    By A7594217 in forum NSR50, NSF100F, MB5, NS1 and RCV Mini
    Last Post: 11-19-2007, 02:19 PM
  3. 65 back brakes DONT work...????
    By rford426 in forum KLX110, DRZ110, TTR90
    Last Post: 07-15-2007, 12:58 PM
  4. Headlight wont work
    By Racerx336 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-13-2007, 11:41 PM
  5. dont look at this-cant get to work
    By 96Z50R in forum CRF50
    Last Post: 02-27-2005, 09:23 PM
bad headlight switch ct70
ct 70h
ct70 headlight test
ct70 ko 12v headlight bulb
ct70 rectifier testing
ct70 testing rectifier
headlight not working on ct70
how to test if the headlight buld on a ct70 is bad
if ct70 rectifier not working will the headlight read in alternating current
no power to headlight ct70
