Toby's 77 build.
This is a discussion on Toby's 77 build. within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; New to the forum, bought a 1977 Trail70 for $300. Did not run, bad top end. wiring harness was hacked up....
Results 1 to 8 of 8
    tober113's Avatar
    Jul 2012
    Toby's 77 build.
    tober113's Avatar
    Jul 2012
    I will be rebuilding the original motor but I want to play on it now.
    I plan to put in a new Lifan 125 4speed manual clutch
    full 12v conversion
    new tires, brakes, lights, controls, suspension etc
    let me know your opinion and suggestions.
    I ride sportbikes and have done extensive mods and maintenance to many bikes but im new to minis
    50mAfIa's Avatar
    Apr 2004
    Moval SoCal
    Get one of the 140 or 155 engines. U will be happier.
    tober113's Avatar
    Jul 2012
    Quote Originally Posted by 50mAfIa View Post
    You are probably right, but the engine is already ordered. Maybe a 160 in the future.
    tober113's Avatar
    Jul 2012
    Finally got the ct back together.
    New Lifan 125 manual
    New wiring full 12v conversion, headlight, tailight etc
    New grips, levers, mirrors
    New carb, air filter, gas tank
    New rear shocks
    New cables
    New brake shoes
    Changed oil - Mobil1 10w40 full synthetic
    Engine bolted right up. wiring was such a pain, so much extra stuff with the 12v system and the battery wouldn't fit under the seat with the supplied tray.
    Just waiting on the new footpegs, exhaust, and tires to get it on the road.
    still want/need a new seat and want to do a full disc brake swap in the front including new forks.
    is lurking...
    HondaFiddyMan's Avatar
    Dec 2009
    Cumming, GA (Atlanta area)
    Drain the synthetic oil before you ride the bike.
    These clutches HATE that stuff...
    -HFM
  7. #7
    tober113's Avatar
    Jul 2012
    Quote Originally Posted by HondaFiddyMan View Post
    -HFM
    Actually, I tried to ride it before reading your post and it acted funny as hell. I came on here to ask but i think you already answered my question sir.
    it started right up no problem, wouldn't shift into first gear (down) from neutral. Also when I shifted up from neutral with clutch lever in,l it killed it as if the clutch wasn't disengaged. ok, so i tightened the clutch cable, while on the center stand the wheel would not spin easy while in gear.
    then i tried to shift the gears while bike was off, starting in neutral, again i could not shift down while turning the back wheel, it would shift up one gear but would spin with an excessive amount of friction. then it would shift up into another neutral????? tire spun freely with clutch lever out. it would also shift up once more from there and do the same, spin with a lot of friction.
    this is supposed to be a 4speed manual clutch 1 down 3 up etc
    this shit is confusing
    I will try and change the oil, what would you recommend i run?
  8. #8
    ride with the wing's Avatar
    Jun 2012
    South East Idaho
    Tober13 when you wired up the 12v system did you use a rectifier or did you just run everything off the battery and the motor?
  1. my next build...
    By kawasakicoby125 in forum Chinese/Import Minis - General Discussion
    Last Post: 06-08-2010, 10:37 PM
  2. SSR 110 A1 build w/ssr125 build questions (wiring)
    By bigmase840 in forum Chinese/Import Minis - General Discussion
    Last Post: 01-11-2010, 06:04 PM
  3. Crf 50 build
    By jake16 in forum CRF50
    Last Post: 10-30-2009, 08:21 AM
  4. My first build
    By Wiley in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-25-2009, 06:07 PM
  5. my new BBR build
    By Triso-mx in forum CRF50
    Last Post: 02-22-2009, 09:34 AM
