CT70 Piston hitting cylinder head?
This is a discussion on CT70 Piston hitting cylinder head? within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Hey guys, first post here. Just discovered this great resource! And just so happens I have a problem. Just getting finished up on a restoration ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By mexicanyella
Thread: CT70 Piston hitting cylinder head?
    cgatto's Avatar
    Sep 2012
    Yellowknife, Canada
    Just getting finished up on a restoration of a 1971 CT70, and put the engine back together. I thought I got it timed pretty well bang on. At TDC the timing marks for the chain matched up almost exactly. The engine spun over and all was well. However, after I torqued the cylinder head acorn nuts to spec, the piston hits the top of the cylinder now! Grr! Is it a timing problem? I should mention that I've installed a new cylinder. It's not a Honda original either. Is that the problem? Or is it valve timing?
    is needing funding for parts...
    and whiskey.
    Brodie's Avatar
    Mar 2012
    Gold Coast, Australia
    Welcome. Hmm just double check that the cylinders are exactly the same length. And that the head gaskets are as well. I know some are thinner causing the valve clearance to drop.
    Also pull the cam cover off and just double check the timing and try to get it exactly spot on. At high RPM with a little valve float and timing out things can go terribly wrong.
    Hidden Content , Restoration project begun 06.March.2012 Rebuilt 24.March.2012 Improvements Ongoing
    Hidden Content
    , Planning begun 10.April.2012 Building Began 01.May.2012 Powder Coat and fine tuning to go.
    Hidden Content , Revival attempt begun 1.September.2012 Got Bored, Given Up For Now.
    Hidden Content , Partial restoration begun 3.January.2013
    is interested in internal
    combustion engines
    mexicanyella's Avatar
    Aug 2008
    Troy, MO
    You didn't install a non-original cylinder head, did you? Non-Honda (Chinese) heads I've seen are patterned after the later, 12-volt CDI Honda motors, which have a shallower combustion chamber and won't work with a early, 6-volt-style piston and its higher domed crown.
    Special~K likes this.
    cgatto's Avatar
    Sep 2012
    Yellowknife, Canada
    Quote Originally Posted by mexicanyella View Post
    I think this may be the case. I've sent back the Chinese cylinder head and ordered a time-sert kit to fix the original Honda head. I'd rather use the quality Honda head anyways, so we'll see if that fixes the problem. The combustion chamber on the chinese copy and the original do indeed look a little different. They measured about the same but the original is definitely tapered a little deeper. When I swap them out I'll report back!
    combustion engines
    Aug 2008
    Troy, MO
    What's the deal with the stock head...stripped spark plug threads or something? If it turns out your original head is toast, a rebuildable core (or one that could just be slapped on and run after cleaning it up) should be easy to find and inexpensive.
    Regarding the compatibility of early/late-style parts, the later 12V motors not only had a shallower head recess and flatter piston crown; they also had a longer connecting rod, so the piston pin hole is located higher up in the piston itself (closer to the ring grooves and piston crown), whereas the earlier 6V motors had a shorter connecting rod, a piston pin hole lower down on the piston, the taller dome on the piston crown and corresponding deeper combustion chamber to accomodate the piston dome.
    And the 12V cranks have a different, more abrupt taper on the flywheel end, whereas there are a couple different 6V crank tapers to suit either the fixed-timing points magnetos that came on the three-speed semi-auto motors or the centrifugal spark advance points magnetos that came on the 4-speed manual-clutch motors (CT70H, SL70, CL70, XL70)...and probably some exceptions to that. I believe C70 passports had the latter type of ignition along with an auto clutch.
    Just things to be aware of if you're looking at older motors as parts sources...
    Hammmerhead's Avatar
    Aug 2014
    I know Im resurrecting an old thread but I ran in to this just recently. Had a lot of parts laying around like an old style OEM 70 short rod or 6v piston and a new cylinder, don't know which style the cylinder is, but it came with a 12v piston. Also had a reproduction new style head which Im assuming is Chinese for a 12v engine. Anyway, there was a valve clearance issue and I doubled the head gaskets. I would have doubled the base gasket, but they were too thin for it to give enough clearance. I don't know if I will run in to an issue in the short term, but its running pretty strong. Im figuring the compression is up there a little over stock.
    JLogan's Avatar
    Sep 2012
    Confession Time: I recently installed a TB 88cc kit and had trouble with the piston hitting something to stop the rotation of the fly wheel. Eventually I figured out that I had used the head gasket from the CT70 gasket kit, (being the cheapskate that I am, I thought I'd save the gasket from the 88cc kit). However, I realized this after I had re-lapped the valves for the second time. Hopefully the little bit of leaking from one of the valves (carb cleaner test) won't affect the rebuild.
    I was really mad at myself for being such an idiot!
    So just a word from the "don't do this at home" folks: Make sure to use the right gaskets from the right kit.
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by JLogan View Post
    leaking valves, for sure, will effect the ability of the motor to run.
  1. kamikaze 143 kit-piston hitting head/valves?
    By shoehorse33 in forum KLX110, DRZ110, TTR90
    Last Post: 01-24-2010, 10:01 AM
  2. Replies: 4
    Last Post: 12-02-2009, 06:16 PM
  3. aftermarket piston TOO LONG!! hitting head!!
    By yz80rider586 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-04-2009, 05:46 PM
  4. 56mm piston hitting head?
    By WFOfromthegetgo in forum Chinese/Import Minis - General Discussion
    Last Post: 05-15-2006, 04:23 PM
  5. HELP on 115 takegawa..piston hitting head
    By sik50sbrady in forum CRF50
    Last Post: 06-24-2005, 05:06 PM
crf50 piston hits head tdc after rebuild
ct 70 piston
ct70 dome piston
ct70 head
ct70 piston install
honda 70 head
honda 70 piston kit
honda ct70 head identificaton
honda piston hits cylinder head
piston hits cylinder head for honda z50
piston hitting cylinder head
yuotub ct 70 chines piston
