Did honda ever make a 125 engine that fits our bikes?
This is a discussion on Did honda ever make a 125 engine that fits our bikes? within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Will a 125cc engine from an 80s 4 wheeler fit our bikes? Its electric & pull cord start. Or is it an engine like on ...
Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By モンキ
  • 2 Post By fastatc70
Thread: Did honda ever make a 125 engine that fits our bikes?
    DSR BLACK DEATH's Avatar
    Feb 2006
    South texas
    Or is it an engine like on a ct90 to where its bigger and will not fit the frame?
    Here's tge only pic he sent of it. Its a horizontal engine also.
    Hidden Content Toooooo many mini bikes
    84z50, 91z50r, 95z50r, 91 & 99z50r apart, xr50, 2-xr70s, 03xr100, 08 hayabusa
    1999 & 2000 Jincheng Pandas stock n street legal....
    2 - 2013 skyteam flashback Red & black
    2-71 ct70s
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    No.
    The biggest original honda engine that fits is the honda nice 110 (ZN110).
    Feb 2006
    South texas
    So this 125 is like a bog block ct90 style then?
    What all years were the 110 made that will fit?
    Atvs only had em?
    2-71 ct70s
    nielspbr's Avatar
    Feb 2008
    See a nice 110 as a modern version of a honda cub (or a big wheel scooter with a normal drivetrain)
    There are 4speed manual and 4speed semi versions.
    The scooter/engine was made in Thailand. But not anymore, it is followed up by the nice/wave 125. These 125 engines do not fit.
    The zn110 engine can be tuned till 175-180cc (58-59 bore, 66mm stroke.) google for tjr, trp, hsm. Closer to home, fpm can do some tricks as well .
    モンキ's Avatar
    Jun 2013
    south
    How about Grom 125?
    DSR BLACK DEATH likes this.
    is fast = 2 money and pain?
    fastatc70's Avatar
    Jun 2012
    Northbrookfield, MA
    I think the atc 125m is a horizontal motor like the xr50 motor. The motor is pull start and electric start. The motor is also one of the first CDI. Motors. Hope that helps.
    fastatc70's Avatar
    Jun 2012
    Northbrookfield, MA
    I have trans planted a 125m motor into a atc70 for a neighbor. The motor bolted in but was a little longer. The motor also had a head stay mount. Wiring was a little of a challenge because of the electric start and the CDI.
    elixur and minirider82 like this.
    Feb 2006
    South texas
    Wait so it will fit or it will not?
    And its cdi you say? Even better.
    Its a complete four wheeler running. Carb needs rebuilt.
    2-71 ct70s
  10. #9
    Feb 2006
    South texas
    Quote Originally Posted by モンキ View Post
    How about Grom 125?
    Now that'll be bad azz....
    2-71 ct70s
  11. #10
    theraymondguy's Avatar
    May 2010
    Niagara, ON
    nielspbr is correct.
    To my knowledge, the only engines that share the common 50/70 mounts are:
    Nice 110
    CA/C 200 (90cc)
    ATC/CL/CT/SL/XL 70
    CRF/XR/ Z50
    C/CA 110 (50cc)
    The three wheeler engines from the 70s up to 125cc (aside from the atc 70) share the bolt pattern that's common with the SL90, CT90/110 which will NOT on their own bolt into a 50/70 style frame.
    I believe Fatcaaat has successfully done a conversion (NOT bolt on). There are kits to fit 50/70 style engines into the 90/110/125 frames but not reverse to my knowledge - which is not exhaustive.
  12. #11
    is Leaning heavily towards
    unloading some minis.
    elixur's Avatar
    Dec 2007
    Washington
    Fastatc70 is correct my cousin put a 125m in an 80s z50 when we were in hs. I don't remember if he had to speed the engine mounts or not but I know it was very little work getting it in there. His issue was the footpegs.
    If u get that quad let me know I might want some parts.
  13. #12
    Feb 2006
    South texas
    I think it may be the same as when I did a search an atv forum pops up and one posted to swap a lifan 125 if his engine was blown.
    Now he didn't do the swap as it was something minor.
    I was also reading that some have a gear reduction in it.
    I don't know if this has it also. The guy seems to know nothing about it or enough about it.
    2-71 ct70s
  14. #13
    elixur's Avatar
    Dec 2007
    Washington
    There should be a high low switch on the side of the case I want to say shifter side if I remember correctly. Its been years since I've seen it.
    I talked to my cousin he said he remembers the motor mounts being off by about 1 inch on the top mount. Said he thinks they used a piece of flat stock to make a little bracket but wasn't positive. That engine is gonna be HEAVY in a 50.
  15. #14
    larrynsr's Avatar
    Aug 2012
    oregon
    I put a atc125 motor in my 1993 ct70 about ten years ago. The top mounting ear had to be machined off a bit to clear the top mounting bolt on the ct frame. The lower mounting ear I had to fabricate an adapter bracket. The front sprocket was a larger chain size so I had to turn down the width of it to fit the 420 chain. Overall it had good power but trans ratio was a bit lower geared. Good for off road but not much speed different on the street. It had a sub transmission. In 1st gear low, it could climb a wall at idle. Wiring was very simple...since both bike and engine were factory cdi ignition. I even got extra over rev with the stock ct70 cdi because the atc125 engine was not the wasted spark type ignition...as the pickup was on the cam.
  16. #15
    Feb 2006
    South texas
    Ok well I passed on it the guy didn't call me back today so I'm sure he sold it.
    2-71 ct70s
  1. 2 peg mounts + foot Peg Fits most Pit bikes
    By pitster pro in forum Import/Chinese Parts for Sale
    Last Post: 01-22-2013, 10:28 PM
  2. honda engine Trail Bikes 88 kit
    By RebelRider corona ca in forum CRF50/CRF70 Parts For Sale
    Last Post: 05-20-2010, 11:39 PM
  3. honda 50 engine motor make offer
    By ahonda17 in forum Feelers and What is my bike/parts worth?
    Last Post: 12-09-2009, 10:17 AM
  4. How to make a Lifan engine look like a Honda
    By The 26incher in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-31-2007, 11:18 AM
  5. 01 Honda engine w/ Trail bikes 88cc for sale
    By vegatron75 in forum CRF50/CRF70 Parts For Sale
    Last Post: 12-20-2006, 09:50 PM
125m into z50r
atc125 engine in crf50
atc125m sub transmission convert
biggest engine in a honda z50
grom engine on ct70
honda 125cc horizontal engine
honda atc pull start not turning engine over
honda ct70 grom motor
planet minis what engines fit our bikes
planetminis what engines fit our bikes
planetminis what engines fit our bikes nice 110
will chinese 125 bolt ct70
