Need easy rebuild advice--stator/points 69 z50
This is a discussion on Need easy rebuild advice--stator/points 69 z50 within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I want to order this rebuild kit from CHP to replace all the electronics on my 69 Z50 on the engine. However the 2 phillips ...
Results 1 to 4 of 4
    Dan Z50's Avatar
    Nov 2012
    I want to order this rebuild kit from CHP to replace all the electronics on my 69 Z50 on the engine. However the 2 phillips scews that hold the stator plate to the engine case were stripped out by somebody else previously. So my simple rookie question is, can I replace all the electronics without actually taking off the plate itself? The rebuild kit comes with a rubber ring gasket, I am assuming this would be the only part I couldn't replace in my situation? I don't want to mess with the stripped screws right now if I don't have to.
    (CHP rebuild kit shown and my actual bike below that)
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Yes you should be able to. When you put the screws for the coils back on use a sealant on the threads. Are you sure you need all of that. The original stuff is better quality
    Ride on the edge
    Dan Z50's Avatar
    Nov 2012
    Well, I'm still trying to resolve the "no start" problem on my blue bike since I got it, I figured this would be a simple and cheap way to "most likely" eliminate any of these parts as the problem ($32). I don't know if what's in there now is original or not as it was restored before I got it (maybe one of the experts can tell from the pic?)
    I'm not quite able to get into the garage yet (just got 10 inches of snow Friday sheesh!) but want to start getting ready for spring work on the bikes.
    I would like to install the other motor you rebuilt for me into this bike while I finish up the red one I have planned for it originally, so I can at least hear it run, have some fun with it and see what carb to use, but if I can't get the blue one started with it's current engine, there's not much point in putting in a different one that I haven't fired yet either. (in case it's a problem on the bike, not the engine).
    I'm about ready to just bring this blue one to a dealer and tell them not to call me until it runs!
    is 10 year member still has no
    status
    spiz5's Avatar
    Feb 2004
    Frankfort Il
    I recently put that kit in my 76 without removing the backing plate. Its a little harder to solder the condensor wires, but no big deal.
  1. ishock rebuild? Need advice
    By Caper in forum CRF50
    Last Post: 05-20-2017, 09:23 AM
  2. Need some easy advice...how find vin, how to start old honda mini 50
    By whiteonwhite in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-20-2012, 08:31 AM
  3. Rebuild Kit For Stator?
    By honda4life818 in forum 1973-1985 ATC70 and TRX70
    Last Post: 07-28-2011, 07:42 PM
  4. Need Advice On A Points Engine Swap Into Crf70
    By PigIron in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 04-30-2011, 06:12 PM
  5. stator rebuild
    By oldskol50 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-20-2005, 11:50 PM
ct70h stator plate
stator replacement
z50 points
z50 stator
