'77 z50 mild rebuild - need some gearing advice
This is a discussion on '77 z50 mild rebuild - need some gearing advice within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Hi all, been lurking for a little, but now am a full fledged planet mini member. Anyway, I'm in the process of rebuilding my 1977 ...
Results 1 to 3 of 3
    Jerm21's Avatar
    Mar 2015
    Mild z50 build - need some gearing advice
    Anyway, I'm in the process of rebuilding my 1977 z50 which I have owned since I was 13 (and put a million miles on ) I'm keeping it pretty stock, but am adding a 72cc cylinder and piston.
    My question is gearing. It has the 12/37 stock gears. I plan on making it street legal just for fun. I'm looking for some input on what sprocket setup would give a nice balance of enough umph to get out of its own way but also a little more top end. FWIW - I weigh about 155. Along that same line of thought... Any recommendations for chains?
    thanks,
    jeremy
    is an old fart.
    Mini K1's Avatar
    Oct 2013
    Northern California
    is an old fart.
    Mini K1's Avatar
    Oct 2013
    Northern California
ID:	158412Click image for larger version.
ID:	158413Using the speed calculator that I listed on your previous post, you can formulate an idea of what you want. My 14/35 combo gives me 32 MPH on my speedometer.
  1. ishock rebuild? Need advice
    By Caper in forum CRF50
    Last Post: 05-20-2017, 09:23 AM
  2. Advice On Shock Rebuild...
    By brap in forum 2 Stroke Pitbikes
    Last Post: 02-20-2012, 06:34 PM
  3. Gearing Advice for CT copy
    By AHRMA361 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-23-2007, 11:01 AM
  4. Advice for clutch rebuild
    By PDR447 in forum CRF50
    Last Post: 03-17-2005, 05:09 PM
