Honda Z50 Restore Project #4
This is a discussion on Honda Z50 Restore Project #4 within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Picked this up for $180. Looks like frame, forks and hubs are in great shape. Rims and handles bar are not any good. I plan ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Like Tree3Likes
Thread: Honda Z50 Restore Project #4
    Crappie Master's Avatar
    Mar 2014
ID:	174697 Click image for larger version.
ID:	174698 Click image for larger version.
ID:	174699 Picked this up for $180. Looks like frame, forks and hubs are in great shape. Rims and handles bar are not any good. I plan to put a atc 70 fork top plate on it, so i can put regular handlebars on it. I ordered a set of chrome rims and tires off ebay for $150. I couldnt pass up that deal. I need buy a bench buffer/polisher. I really want to polish the hubs. This was to be next winters project,but since i have a delay in building my garage i figured i would work on this a bit. Engine doesnt run. I will buy a Piranha 70CC engine to put on it.
    MMR
    MMR is offline
    MMR's Avatar
    Apr 2016
    Boise ID
    Great start
    Sent from my XT1585 using Tapatalk
    Mar 2014
ID:	174950 Click image for larger version.
ID:	174951 Click image for larger version.
ID:	174952 Click image for larger version.
ID:	174953 Click image for larger version.
ID:	174954 Click image for larger version.
ID:	174955 Click image for larger version.
ID:	174956 Click image for larger version.
    MMR
    MMR is offline
    MMR's Avatar
    Apr 2016
    Boise ID
    Looking gd
    Mar 2014
    Also the Harbor Freight portable sand blaster work pretty well. I need to put the water trap on air line before i use blaster again. The moisture just makes things messy and unneccassarily more dufficult. I ran the PSI at about 75. Next time i will try 100 PSI. At this time i'm thinking of paint bikes frame red. Then the fenders, gas tank and wheels will be chrome. The handelbars and seat mounting hardware will be black. I'm working on getting a grinder/ buffer from a friend. I've done a bunch of research and have learned which buffing wheel to get with what buffing compound to polish my aluminum wheel hubs. Also you can see in my pics i have bought a a honda atc 70 triple tree top plate and handler bar clamps.
    Mar 2014
    So i got a bench grinder from a friend. I ordered 2 spiral sewn 6" buffer pad with brown(tripole) and white buffing compound. I have a have few more parts on order. I post pics tomorrow. Also i plan to give this bike to a friend when i'm done.Please don't tell him 👌🏻
    Mar 2014
ID:	175148 Click image for larger version.
ID:	175149 Click image for larger version.
ID:	175150 Click image for larger version.
ID:	175151 Buffed brake hub with a 6" spiral sewn buffing wheel and brown rubbing compound. The actual buffing process is pretty easy. The removing clear coat with paint remover, removing dirt and discoloration from aluminum with Purple Power and steel whole is hard. I will polish all the part with the brown compound before changing to a different 6" buff wheel and white rubbing compound Click image for larger version.
    is still learning...
    bigredx7's Avatar
    Dec 2015
    Acworth, Georgia
    So far so good! I bet it will look great when you are finished. Keep up the nice work.
    Go Easy
    Hidden Content
    '74 ct70
    '88 zb50
  10. #9
    is zero fox given
    rustynuts's Avatar
    May 2014
    Norcal
    Looks great! If you have a decent compressor, you can soda blast the clear coat and grime.
    Check out my Pitster mini monster zb50 thread: Hidden Content
  11. #10
    is When minibikes are outlawed,
    only outlaws will have
    minibikes. You can have mine
    soon as you pry my cold dead
    fingers off it.
    davmo's Avatar
    Dec 2011
    Minibike, Texas.
    Don't know if you saw this already, but there is a method for speeding up hub polishing in this thread:Aluminum polishing time. Z50 Wheel hubs, brake panels, and tripletree clamps.
  12. #11
    Mar 2014
ID:	175271 Fenders just showed up. I think they look awesome.
  13. #12
    is 10 year member still has no
    status
    spiz5's Avatar
    Feb 2004
    Frankfort Il
    Are those parts from Webike? Ive never seen Tanaka parts sold by anybody else.
  14. #13
    ahwest's Avatar
    Nov 2015
    what is that tanaka part called?
  15. #14
    loopiemclooperson's Avatar
    Oct 2011
    Maple Valley WA
    ^^^^^^^ A chain adjuster.
    TANAKA TRADING : Chain Adjuster [ca758]
  16. #15
    Mar 2014
    The fenders were also Tanaka. Bought them off Ebay. From "socalct70parts"
  1. 1980 ATC70 Restore Project #4
    By a7t0c in forum 1973-1985 ATC70 and TRX70
    Last Post: 06-11-2016, 12:18 PM
  2. Honda atc 70 restore project #3
    By Crappie Master in forum 1973-1985 ATC70 and TRX70
    Last Post: 04-05-2016, 07:56 AM
  3. 1972 Honda Z50 K3 Restore Project
    By Loretta72honda50k3 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-20-2013, 04:26 AM
  4. 1982 Restore Project
    By Shutt24 in forum 1973-1985 ATC70 and TRX70
    Last Post: 02-10-2010, 09:48 AM
  5. restore project
    By badkippy in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-23-2006, 06:52 PM
