Z50, CT70 and ZB50
VIN Driven Engine Decoder
For All Available Bolt-In Honda Engines
Through 2008
Year Make Model Designation Beginning Vin Ending Vin Remarks
1967 Z50M 67 Z50ME-XXXXX Z50ME-XXXXXX 6V Points Engine
1968 Z50A K0 Z50AE-100001 Z50AE-199999 6 Volt Points Engine
1969-1970 Z50A K1 Z50AE-120088 Z50AE-269999 6 Volt Points Engine
1970-1971 Z50A K2 Z50AE-270236 Z50AE-999999 6 Volt Points Engine
1972 Z50A K3 Z50AE-1000001 Z50AE-2999999 6 Volt Points Engine
1973 Z50A K4 Z50AE-3000001 Z50AE-4999999 6 Volt Points Engine
1974 Z50A K5 Z50AE-5000001 Z50AE-5999999 6 Volt Points Engine
1975 Z50A K6 Z50AE-6000001 Z50AE-6099999 6 Volt Points Engine
1976 Z50A '76 Z50AE-6100001 Z50AE-6199999 6 Volt Points Engine
1977 Z50A '77 Z50AE-6200001 Z50AE-6299999 6 Volt Points Engine
1978 Z50A '78 Z50AE-6300001 Z50AE-9999999 6 Volt Points Engine
1979 Z50R '79 AB02E-5000001 AB02E-5099999 6 Volt Points Engine
1980 Z50R '80 AB02E-5100001 AB02E-5199999 6 Volt Points Engine
1981 Z50R '81 AB02E-5200001 AB02E-5299999 6 Volt Points Engine
1982 Z50R '82 AB02E-5300001 AB02E-5399999 6 Volt Points Engine
1983 Z50R '83 AB02E-5400001 AB02E-5499999 6 Volt Points Engine
1984 Z50R '84 AB02E-5500001 AB02E-5599999 6 Volt Points Engine
1985 Z50R '85 AB02E-5600001 AB02E-5699999 6 Volt Points Engine
1986 Z50R '86 AB02E-5700001 AB02E-5799999 6 Volt Points Engine
1987 Z50R '87 AB02E-5800001 AB02E-5899999 6 Volt Points Engine
1988 Z50R '88 AB02E-5900001 AB02E-5999999 12 Volt CDI
1989 Z50R '89 AB02E-6000001 AB02E-6099999 12 Volt CDI
1991 Z50R '91 AB02E-6100001 AB02E-6399999 12 Volt CDI
1992 Z50R '92 AB02E-6400001 AB02E-6407025 12 Volt CDI
1993 Z50R '93 AB02E-6500001 AB02E-6506519 12 Volt CDI
1994 Z50R '94 AB02E-6506520 AB02E-6512294 12 Volt CDI
1995 Z50R '95 AB02E-6600001 AB02E-6605419 12 Volt CDI
1996 Z50R '96 AB02E-6605420 AB02E-6610729 12 Volt CDI
1997 Z50R '97 AB02E-6610730 AB02E-6615370 12 Volt CDI
1998 Z50R '98 AB02E-6615433 AB02E-6620649 12 Volt CDI
1999 Z50R '99 AB02E-6620650 AB02E-9999999 12 Volt CDI
1988 ZB50 88 AB22E-2000001 AB22E-2100000 12 Volt CDI
1969-1971 CT70 K0 CT70E-100001 CT70E-1999999 6 Volt Points Engine
1970-1971 CT70 HK0 CT70HE-100001 CT70HE-1999999 6 Volt Points Engine
1972-1973 CT70 K1 CT70E-2000001 CT70E-2099999 6 Volt Points Engine
1972-1973 CT70 HK1 CT70HE-2000001 CT70HE-9999999 6 Volt Points Engine
1973 CT70 K2 CT70E-2100001 CT70E-2299999 6 Volt Points Engine
1974 CT70 K3 CT70E-2300001 CT70E-2399999 6 Volt Points Engine
1975 CT70 K4 CT70E-2400001 CT70E-2499999 6 Volt Points Engine
1976 CT70 76 CT70E-2500001 CT70E-2599999 6 Volt Points Engine
1977 CT70 77 CT70E-2600001 CT70E-2699999 6 Volt Points Engine
1978 CT70 78 CT70E-2700001 CT70E-2799999 6 Volt Points Engine
1979 CT70 79 CT70E-5000001 CT70E-5099999 6 Volt Points Engine
1980 CT70 80 CT70E-5100001 CT70E-5199999 6 Volt Points Engine
1981 CT70 81 DD01E-5200001 DD01E-5299999 6 Volt Points Engine
1982 CT70 82 DD01E-5300001 DD01E-5399999 6 Volt Points Engine
1991 CT70 91 DB01E-2000001 DB01E-2199999 12 Volt CDI
1991 CT70 91 CA Spec. DB01E-2000001 DB01E-2199999 12 Volt CDI
1992 CT70 92 DB01E-2200001 DB01E-2202248 12 Volt CDI
1992 CT70 92 CA Spec. DB01E-2200001 DB01E-2202248 12 Volt CDI
1993 CT70 93 DB01E-2202249 DB01E-2206720 12 Volt CDI
1993 CT70 93 CA Spec. DB01E-2202249 DB01E-2206720 12 Volt CDI
1994 CT70 94 DB01E-2206721 DB01E-2229999 12 Volt CDI
1994 CT70 94 CA Spec. DB01E-2206721 DB01E-2229999 12 Volt CDI
2000-2003 XR50R '00-03 AE03E-5000001 AE03E-5199999 12 Volt CDI
2004-2005 CRF50F '04 and '05 AE03E-5200001 AE03E-5299999 12 Volt CDI
2006-2007 CRF50F '06 and '07 AE03E-5400001 AE03E-5499999 12 Volt CDI
2008 CRF50F '08 AE03E-5500001 AE03E-5599999 12 Volt CDI
1997 XR70R '97 DE02E-5000001 DE02E-5006803 12 Volt CDI
1998 XR70R '98 DE02E-5006804 DE02E-5014265 12 Volt CDI
1999 XR70R '99 DE02E-5014266 DE02E-5099999 12 Volt CDI
2000 XR70R '00 DE02E-5100001 DE02E-5199999 12 Volt CDI
2001-2003 XR70R '01,'02 and'03 DE02E-5200001 DE02E-5299999 12 Volt CDI
2004-2005 CRF70F 04 and '05 DE02E-5300001 DE02E-5399999 12 Volt CDI
2006-2007 CRF70F 06 and '07 DE02E-5400001 DE02E-5499999 12 Volt CDI
2008 CRF70F 08 DE02E-5500001 DE02E-5399999 12 Volt CDI
1965-1969 S65 CS65 S65E-100001 S65E-999999 6 Volt Points Engine
1970-1971 C70M K0 C70ME-000001 C70ME-1999999 6 Volt Points Engine
1972-1973 C70 K1 C70E-2000001 C70E-9999999 6 Volt Points Engine
1980 C70 '80 DA01E-1000001 DA01E-2099999 6 Volt Points Engine
1981 C70 '81 DA01E-2100001 DA01E-2199999 6 Volt Points Engine
1982 C70 '82 DA01E-2200001 DA01E-2299999 12V CDI
1983 C70 '83 DA01E-2300001 DA01E-9999999 12V CDI
1969 CL70 K0 CL70E-100001 CL70E-199999 6 Volt Points Engine
1970 CL70 K1 CL70E-200001 CL70E-299999 6 Volt Points Engine
1971 CL70 K2 CL70E-300001 CL70E-1299999 6 Volt Points Engine
1972 CL70 K3 CL70E-1300001 CL70E-999999 6 Volt Points Engine
1971-1972 SL70 K0 SL70E-1000001 SL70E-1999999 6 Volt Points Engine
1973 SL70 K1 SL70E-2000001 SL70E-9999999 6 Volt Points Engine
1974 XL70 K0 XL70E-1000001 XL70E-1099999 6 Volt Points Engine
1975 XL70 K1 XL70E-1100001 XL70E-1199999 6 Volt Points Engine
1976 XL70 K2 XL70E-1200001 XL70E-1999999 6 Volt Points Engine
Miscellaneous Odd Models
1982 C70 '82 DA01E-2200001 DA01E-2299999 6 Volt Points Engine
1983 C70 '83 DA01E-2300001 DA01E-9999999 6 Volt Points Engine
2000 XR70R '00 DE02E-5100001 DE02E-9999999 12 Volt CDI
