Fatcaaat CL125 build thread. First vertical engine build i have done - Page 2
This is a discussion on Fatcaaat CL125 build thread. First vertical engine build i have done within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Very, VERY cool....
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 75
Like Tree32Likes
Thread: Fatcaaat CL125 build thread. First vertical engine build i have done
  1. #16
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Very, VERY cool.
    50 Nuts
    Fat Tires Rule
  2. #17
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Exhaust
    I spent time doing the exhaust today. It was actually pretty easy to do this and it came out just as I wanted it. It may not be as pleasing to the eye to some, but this was absolute purposeful in that it allows that hallow center of the bike to really stick out. I started with the stock crf230 header and expanded to 1.25 then to 1.375 and then used 1.5 mandrel bends that were chopped and welded back together. It all came out pretty good I must say. I have a 17" long reverse cone muffler on there that I had in the shop. I may elect to use it or may go with something a little shorter like a supertrapp.
ID:	193754   Click image for larger version.
ID:	193762   Click image for larger version.
    kirrbby, cbinvb and Quinc like this.
  3. #18
    is busy convincing his wife he
    has 1 bike with many sets of
    plastic....
    Chum's Avatar
    Sep 2016
    Virginia
    Lookin' really nice, good job, can't wait to see finished product!
    Am103's Avatar
    May 2014
    Iowa
    I really really like where this is going....MORE PICS!
    Not addicted. Hidden Content
  6. #20
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    I have the beast running now. https://youtu.be/4HqiuBEUZtQ
    This is just the recommended webcam grind, stock carb jetted 48/125 and a the stepped exhaust using the stock header. Goes from 1.125 to 1.25 to 1.375 to 1.5 to the reverse cone. It revs surprisingly quick.
  7. #21
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    a little progress
    I am making a little bit of progress...held up by the fact that my tool to enlarge the triple tree got lost in the mail...so had to reorder one.
    The wheel spacing is correct, although the axle is a little shorter than I'd like...so I need to find another axle for that I think. The upper triple tree needs to be enlarged from 44mm to 45mm...this is from an RS125 and was the closest I could find for my fastace triples. These are 173mm wide and have a 55mm offset. I also had to swap the stem out of these for a ct70 length stem...no problem there.
    The good news is that the triple trees do not hit the tank, like the first set did, thanks to that offset.
    The headlight brackets you see here are too long and look out of place, so I ordered up some other ones that push the headlight back about 1.5" closer to the trees. From a fabrication point of view, the only thing left is the front brake caliper bracket and the foot peg connections to the rear brake and the shifter. Only part I'm missing is a throttle cable.
    Once it is all together and functioning, I may keep it assembled until the spring when I can take it back apart and have it powdercoated. I am undecided on the swingarm if I will keep it or make another one. This one is not perfect but certainly servicable.
    Attached Images Attached Images
    minishifter and kirrbby like this.
  8. #22
    is When minibikes are outlawed,
    only outlaws will have
    minibikes. You can have mine
    soon as you pry my cold dead
    fingers off it.
    davmo's Avatar
    Dec 2011
    Minibike, Texas.
    Looking good, Jarred!
  9. #23
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Well, the tool to open up my top tree is sitting in California and the headlight brackets are sitting in New York. These are the two items preventing me from having a roller at this point. I'm getting anxious!
  10. #24
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    still delayed on the top tree, but I did manage to get all of the bike wired other than the headlight and the controls. Also, I fabbed up the brake mount for that brembo crab I'll be running up front. This is made from 1/4" 6061 Aluminum. I have to metal finish it, but it will be PC'd anyway, so not too concerned. This ought to stop the beast. Same crab caliper going to be used on the back as well.
  11. #25
    sharky nrk's Avatar
    Feb 2015
    Hutto, TX
    This build is AMAZING and now I want one lol.
  12. #26
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    It's really coming together. Only problem I have with it is that you make it look so easy
    loopiemclooperson likes this.
    50 Nuts
    Fat Tires Rule
  13. #27
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    THe g'craft triple trees are from an RS125 with 44/48mm tree bores. The fast ace are 45/48. So the trees had to be bored out on the top. So we spent about 2 hours taking care of this. 45 minutes was spent screwing around with the gauge that worked great for the first one, but then the indicator needle fell off, and then the rest of the thing messed up. Eventually, I smashed it to the ground and did the second one by eye/hand without indicating it...worked fine.
    Here's my buddy mike working on getting the machining done.
ID:	197465   Click image for larger version.
ID:	197473   Click image for larger version.
ID:	197481   Click image for larger version.
ID:	197489   Click image for larger version.
  14. #28
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    The tree was then installed, the headlight brackets, speedo/tach, and the headlight bucket. Handlebars attached. Starting to shape up. I just have to install the neck bearings, install the brakes, shorten the rear axle, and finish up some wiring and we'll be ready to test drive.
ID:	197505   Click image for larger version.
ID:	197513   Click image for larger version.
    Chum and nielspbr like this.
  15. #29
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    It's really coming together now!
    50 Nuts
    Fat Tires Rule
  16. #30
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    In this lighting the bike almost looks steampunk.
  1. Fatcaaat CL125 build thread. First vertical engine build i've done.
    By fatcaaat in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-15-2016, 10:26 AM
  2. 1966 Ct90Ko Scoot Build Thread, And Engine Construction
    By 50rider340 in forum Bigger Minis Forum
    Last Post: 09-09-2011, 02:50 AM
  3. Replies: 6
    Last Post: 05-08-2011, 02:58 PM
  4. YX engine build thread?
    By blackjer in forum Chinese/Import Minis - General Discussion
    Last Post: 03-20-2008, 03:21 PM
