Fatcaaat CL125 build thread. First vertical engine build i have done - Page 3
This is a discussion on Fatcaaat CL125 build thread. First vertical engine build i have done within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I got my rear axle and sprocket carrier finally sorted and I was able to complete the wheels and brake hangers. It is very close ...
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 73
Like Tree28Likes
Thread: Fatcaaat CL125 build thread. First vertical engine build i have done
  1. #31
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    I got my rear axle and sprocket carrier finally sorted and I was able to complete the wheels and brake hangers. It is very close now. All I need to do is put the brake lines and throttle and sort the shift linkage and I can test ride it. Sure is comfortable on the seating.
ID:	197721   Click image for larger version.
ID:	197729   Click image for larger version.
ID:	197737   Click image for larger version.
ID:	197745   Click image for larger version.
    cbinvb and minishifter like this.
  2. #32
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Here is a compare shot...probably could have done some more, but the battery died on the phone when I was taking the pictures. Here you can see it next to a stock CT70 with the front axles lined up. You can see that the seat height is about the same and the bar height is only about 2 inches shorter. Wheelbase on the new bike is 52" It is extremely comfortable to sit on...surprisingly so actually.
  3. #33
    sharky nrk's Avatar
    Feb 2015
    Looks great. Love it.
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Wow! Great pix. Awesome to see it side by side. I was picturing a much bigger bike. Totally shocked. Love it
    50 Nuts
    Fat Tires Rule
  6. #35
    cbinvb's Avatar
    Apr 2010
    Baltimore MD
    Gettin real close. Post a pic of the leveled out stance once you have it.
  7. #36
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Here's the final assembly of the rearsets and linkages. I did a custom linkage for shifting since the one that came with was pure garbage. Instead I got myself some 3/8" 6061 aluminum rod, turned the ends in the lathe and threaded them, and then added a heim joint to both sides with an adjuster nut. Now I have adjustability to put the lever up and down about an inch in either direction depending on my need. I'll finish this out with some finishing hardware, but the mockup and spacers are done here and it works perfect.
    ON the brake side, i'm using the stock 250r master that needed a little modification to the body to clear the mounts. I also had to cut the length of the threaded extender down. I'll use a nice remote billet reservior with stainless braided line when it's done.
ID:	199353   Click image for larger version.
  8. #37
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    The bike is now nearly complete in the first rideable mockup version. All the wiring is completed and 95% of all fabrication is completed. I still have to finish the battery box, mount a horn, add some additional brackets for the rear fender, and make up an ignition switch mount. Also have to put the center stand on it, but that is a direct mount from original so hoping it is pretty straight forward. For wiring, I'm going to take the wiring harness back out and clean it up by removing connectors in place of soldered connections.
    It runs perfect and sits very nice. I did manage to ride it just a tiny bit as the roads were covered with water today and it was about 34 degrees so I didn't go much with it. And since it only has a front brake currently connected, I did not want to have to pull hard on the brake and have an incident in the wet.
    I'll probably clean up the harness while the bike is still in this form, and do a few other metal work before it is completely broken down for powdercoat. I intend on keeping the color scheme as it sits, but also have a non-chrome tank in the mail that I may paint a vintage honda color. I also have a brat style seat coming that will be direct swappable.
ID:	199369   Click image for larger version.
ID:	199377   Click image for larger version.
    loopiemclooperson likes this.
  9. #38
    loopiemclooperson's Avatar
    Oct 2011
    Maple Valley WA
    Lookin sharp. Top notch build as always. Are you going high or low on the front fender?
    Sent from my SCH-I545 using Tapatalk
  10. #39
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    I was able to get on it today and give it a few passes in the neighborhood and then took it out onto an adjecent roadway. I had it running pretty fast in 5th...probably close to redline and then into 6th but needed to slow down. bike is pretty solid and stable. Needs to have a few things dialed in and such. It's fast...faster than any mini I have in my stable...faster than my trp176cc honda CT70. That is certain.
    I will say for sure I will be putting a front fender on it and will probably fabricate up a back splash guard as a permanent fixture before powder.
  11. #40
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    That's a good lookin bike fatcaaat. Nice work. How's the size of the bike. How does it 'feel" compared to your CT70's? Slightly bigger? A lot bigger? Still feel like a mini?
  12. #41
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by kirrbby View Post
    Well, i haven't had enough seat time, but I guess I could offer a bit of a comment to it. Seat height, it is the same as a stock ct70 and actually 1" shorter than two of my CT's as configured. Lengthwise, the wheel base is much larger at 51" The bike is well centered and low to the ground so it seems to handle well for the little I've ridden it. It is very comfortable. Sits exactly like a stock Norton Commando with better hand position. You are mostly on your butt with maybe 5% of your weight on your wrists.
    The CRF230 is not rev up super fast, but it has a huge flywheel and crank since it is a woods bike. So it idles low and consistent and is really easy off throttle. Since the engine has had some work, with a pipe and a rejet, and a diet of about 60lbs over stock, that engine moves this little bike pretty quick.
    time will tell, but I think this bike will be a great all around fun bike.
    Now the bigger question...is this a mini? I'm not sure. The Honda CL125 in original form? Is that a mini? I probably would say "yes." Since it is basically the same bike as a CL100 and CB100...why not..just a 125 engine. The bike is physically shorter and a little longer than a stock CL100...so still mini. The wheels are actually 16", whereas the stocks are either 17 or 18"...so still a mini. The forks are how shorter....so still a mini. But what makes it hard to call a mini, I suppose, is the powerplant. A mildly worked CRF230 engine is clearly NOT from a mini. But really, if you consider a Honda CB100 a mini, than this bike is a mini.
    Physically it is smaller than a CT110....about the same physically as a Honda CL70 or Honda S90 but with 5x the power.
  13. #42
    is When minibikes are outlawed,
    only outlaws will have
    minibikes. You can have mine
    soon as you pry my cold dead
    fingers off it.
    davmo's Avatar
    Dec 2011
    Minibike, Texas.
    very nice!
  14. #43
    cbinvb's Avatar
    Apr 2010
    Baltimore MD
    "Mini"? I'm not so convinced pal...
    Why does it even matter though? The bike is sick, not another like it in the world. I really wanna see this thing in action
  15. #44
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    I think today I'm going to rewire the bike connections and clean up the harness. Once that is completed there's really not more to do to the bike other than break it down and get the cosmetics completed.
    CBINVB, I'm making an executive decision on this...I'm classifying it as a mini. Other than the motor, everything else falls into the realm of mini. Since it is physically the same size as a CL70 and weighs only a little more than a CT110, I am calling it a mini.
  16. #45
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    Mini it is.
    I was asking about that, because I was curious...And because of the end goals you set back around post #1. I've been following with interest, because I think we all are interested in a better, faster mini. A better, faster motorcycle...Well those are available
  1. Fatcaaat CL125 build thread. First vertical engine build i've done.
    By fatcaaat in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-15-2016, 10:26 AM
  2. 1966 Ct90Ko Scoot Build Thread, And Engine Construction
    By 50rider340 in forum Bigger Minis Forum
    Last Post: 09-09-2011, 02:50 AM
  3. Replies: 6
    Last Post: 05-08-2011, 02:58 PM
  4. YX engine build thread?
    By blackjer in forum Chinese/Import Minis - General Discussion
    Last Post: 03-20-2008, 03:21 PM
