Xl70 / Grom build - Page 2
Xl70 / Grom build
This is a discussion on Xl70 / Grom build within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Originally Posted by geezer I love this build Sent from my iPhone using Tapatalk Comments like that keep me going... Got a little further....
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 40
Like Tree20Likes
Thread: Xl70 / Grom build
  1. #16
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
    Quote Originally Posted by geezer View Post
    I love this build
  2. #17
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    mojomoto likes this.
    Ride on the edge
  3. #18
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    That looks pretty good there. You should do a rear fender bobbed like the style on a bobbed norton commando. Look that up.
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
    I agree. The super open front wheel would look better matched with a more open rear.
  6. #20
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Wow! Really coming together. Looks great. I think you can hack a lot off that fender and even use the license plate for a little more protection if needed...if you are mounting up there.
    Your comment on the weight got me thinking. My boss recently became obsessed with a CB cafe bike. Has never seen one in person and with little to no research, we were driving to pick up a minter 650. A real beauty BUT it's a tank. He rides a bmw (barely) nineT and was after something smaller/lighter to fling about with. BMW scares him a bit I think. The 650 probably weighs more then the BMW. Total fail on his part. Should have bought a 350-360. Not that a grom is a tank but I can only imagine how much more fun this bike will be, especially as it should handle similarly with suspension and brakes. It's brilliant
    50 Nuts
    Fat Tires Rule
  7. #21
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
    Quote Originally Posted by 66Cooper View Post
    Thanks! I think i just might do a shock mount side placed license plate. Brake light....?... must be small and bright. I live in a rural Minnesota town and cops are fairly cool here. I won't be running signals. not sure about a horn. Ill have a single bar end mirror. It will be legal enough....i hope.
    My first street bike was a cb360 so.....i have a soft spot for them. Great little bike. Very clean and classic look..six speed transmission was nice too. ...and have owned cb350f cb500f.. cb550f.. cb350t.. cl350t... cb750.. cb450t..cl450t.. cb500t... out of the cb models Id have to say my favorite all around hands down was the cb550. Lightish, smooth, good for corners, good sound, tough and easy to find parts. Everyone gets hot over the cb750 but i found them to be tall heavy pigs and not all that quick. They may be historically significant, sure....but I've had my fill of them. JMO
    i had a 900cc boxer too....they are strangely really easy to drive. As soon as they get rolling the weight vanishes.
    Forgive my long message just to say.... Yeah...He should have got a 350-360.
    got different bars and hand controls so....just like christmas!!!! Thanks for watching my progress.
  8. #22
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
ID:	200529Click image for larger version.
    loopiemclooperson likes this.
  9. #23
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
  10. #24
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
Name:	My xl70 before.jpg
ID:	200666 Just wanted to send the before pic. Got the cush drive machined and put on. Its a snug fit with the swingarm, sprocket and wheel but it will be good. My vanity got the best of me though...I have a more narrow set of tires to put on it but this set looked so good. The counter sprocket is offset because of this vanity so i will be taking one for the team in finding out how .25+ further out on the input shaft will hold up on a Lifan.
    Also did some research on some sort of pre made 3/4 tube splitters for the right front frame downtube. I was going to make some but i found out that some people customize bicycles and when they want to run a belt in stead of a chain they make the right rear section of the bike frame removable....lucky me. Found a company that makes the splitters and sent an email. They aren't cheap but...it will make engine removal a breeze. Should be worth every penny.
    Google....Images...3/4 frame tube splitters.
  11. #25
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
    Here are the ones that Im checking into.
  12. #26
    cbinvb's Avatar
    Apr 2010
    Baltimore MD
    Veery cool idea. That could easily be used for anyone trying to shoehorn a big crf motor into a little cb100 frame like Fatcaaat over here.
  13. #27
    badkippy's Avatar
    Feb 2005
    Bemidji mn
    Quote Originally Posted by mojomoto View Post
    Building a xl70 custom...
    Putting Grom suspension and wheels on it.
    Just in case someone wants to give it a go themselves...Ill keep you updated in the parts and the work that will be required to do so.
    First of all...Im using an xl70 frame and i do believe a cl70 is very similar. Someone out there please correct me if i am wrong.
    The stock swingarm is too short and narrow for a Grom wheel so i did some digging and investigating and found that a Honda ST90 swingarm fits very well. The id width (at the rear axle adjusters) of the swingarm is 7 and 9/16 and a stock Grom is 9 and 1/8 which is a difference of 1 and 9/16 inches. Yes....the left axle spacer and the brake bracket/spacer need to be machined down 25/32 of an inch to make it fit. Im waiting for parts in the mail and some warmer weather to play in my shop without freezing. (Minnesota)
    Been looking at the triple clamp and so far my best option is to put the stock xl70 bearing post in the Grom lower clamp since the Grom races are bigger. Ill get the 4 inch grinder and grind the weld holding the post in and then press it out then....see what needs to be done.
    If anyone has a better plan.... PM me.
    what part of Minnesota are you from?
  14. #28
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
    Glenwood...bout 12 miles south of Alexandria.
  15. #29
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
    Ordered the frame splitters this morning...Got a new seat the other day and will be working on the offset sprocket next. Ill have fresh pics soon.
  16. #30
    mojomoto's Avatar
    Jan 2012
    Central Minnesota
ID:	201497Click image for larger version.
ID:	201505Click image for larger version.
    Here are some new pics.
    Shortened the exhaust by two inches. Hung too far out the back for my taste.
    Cut down the rear fender to match the less is more look....just a rough cut so far.
    New seat was mounted. Its an sl70 seat and found out the shape of the pan is a bit different than the shape of an xl70. I prefer the sl seat so.... had to lower the rear frame loop about 3/8 of an inch and remove some mount tabs to clean up the look back there. Believe it or not I DID get things accomplished but as with most small changes its most noticeable by the person doing the work.
    The frame tube splitters came in and i need to order some brake lines.
  1. XL70 resto/build looking for advice
    By Tbone77 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-25-2015, 10:24 PM
  2. MY XL70
    By Expygator in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-23-2015, 10:21 PM
  3. My Grom Killer build...
    By xr1million in forum Mini-Motards
    Last Post: 01-01-2015, 03:05 PM
  4. 2012 KLX110L Street build, grom killer... teehee.
    By dillontonsi in forum KLX110, DRZ110, TTR90
    Last Post: 03-21-2014, 12:17 PM
  5. Replies: 9
    Last Post: 08-20-2013, 03:11 PM
