Z50 Front Fork Seal Installation
This is a discussion on Z50 Front Fork Seal Installation within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Howdy, Can someone tell me what side of the Honda z50 fork seal to install up? One side of the seal is open and one ...
Results 1 to 14 of 14
    Davem's Avatar
    Mar 2017
    Howdy,
    Can someone tell me what side of the Honda z50 fork seal to install up? One side of the seal is open and one side is closed.
    Thank you for the help!!
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Picture of the fork seal, please..
    - dirtbkr188 -
    Davem's Avatar
    Mar 2017
    I'm trying to post a pic but can't get it to work.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Okay, how about a picture of the forks? Apparently, you have some type of aftermarket forks on your Z.
    - dirtbkr188 -
    tmas's Avatar
    Apr 2005
    TO
    I'd say the seal on the right is facing the right way when installed.
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Typically, the "open" side of the seal should face inward. The idea being that whatever liquid that is under pressure and you are trying to keep in, is pushing on the openness of the seal, forcing to tighten.
    As asked, pix of forks would be great as stock z50 forks are basically pogo sticks with a wheel at one end
    50 Nuts
    Fat Tires Rule
    Davem's Avatar
    Mar 2017
ID:	203449Click image for larger version.
    Davem's Avatar
    Mar 2017
    I'm 99% sure the forks are the original for a '73 z50. I got these fork seals from CHP that they had listed for a '73 z50.
  10. #9
    CrawlerD's Avatar
    May 2008
    Sin City
    It's actually just a grease seal that goes in the bottom of the silver caps that screw on. The sealers or closed end goes down. And don't over tighten them.
  11. #10
    Davem's Avatar
    Mar 2017
    Perfect, thanks very much!!
  12. #11
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Makes sense. I've been working on later Zs lately and forgot the difference.
    If you have these apart still, you should REALLY consider replacing/upgrading the leg bushings. New ones, or even better, Delrin upgrades improve the feel upfront tremendously. Another step forward would be adding a set of anti-wobble collars to the fork leg/spring union and together, you will eliminate nearly all the back and forth slop
    50 Nuts
    Fat Tires Rule
  13. #12
    is building '72 z50
    Quinc's Avatar
    Sep 2015
    Northern California
    Quote Originally Posted by 66Cooper View Post
    Where can I find one of these anti-wobble collars?
  14. #13
    tmas's Avatar
    Apr 2005
    TO
    Quote Originally Posted by Quinc View Post
    CHP. Check link scroll down to 158. Just below fork guide bushing.
    CHP Motorsports CLASSIC HONDA PRIVATEER RACING Honda Mini Trails Honda mini bikes and Honda Z50 Honda 50 Honda Minitrail NOS Parts and services Kitaco and Takegawa performance parts.
  15. #14
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Look at fast50s or two brothers for the delrin bushings as well. The fit is a million times better and they last...so long as your fork legs are straight. The stock bushings seem to work fine with bent legs but the delrin are made to fit so much tighter that a bent leg may get suck a bit.
    50 Nuts
    Fat Tires Rule
  1. Oil seal installation question - Z50 engine
    By flossy21 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 04-30-2010, 06:24 AM
  2. valve seal installation
    By MpR in forum KLX110, DRZ110, TTR90
    Last Post: 08-19-2009, 01:12 PM
  3. marzocchi fork seal installation question
    By jedsled in forum CRF50
    Last Post: 11-06-2006, 09:01 PM
  4. marzocchi fork seal installation question
    Last Post: 11-02-2006, 01:20 AM
  5. marzocchi fork seal installation question
    By jedsled in forum KLX110, DRZ110, TTR90
    Last Post: 11-02-2006, 01:13 AM
