1985 Z50R Brake Spring Question
This is a discussion on 1985 Z50R Brake Spring Question within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I am having trouble with brake shoe replacement on a 1985 Z50R. I managed to get the U-shaped thick wire brake spring off of the ...
Results 1 to 4 of 4
    Nsxdoc's Avatar
    Mar 2017
    I am having trouble with brake shoe replacement on a 1985 Z50R. I managed to get the U-shaped thick wire brake spring off of the pivot post to take everything apart but am now having trouble with the reassembly. Is there a trick to easily get that brake spring slipped back up over the post? I looked high and low on the internet for how-to's but all I could find was info on older bikes with two regular brake springs.
    tmas's Avatar
    Apr 2005
    TO
    Install the spring on one side. Use a big screwdriver to pry it in on the other side.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Insert one end of the spring in the brake shoe, then put the top of the spring over the post, and lastly insert it into the other brake shoe. It takes some doing, but it can be done.
    - dirtbkr188 -
    Nsxdoc's Avatar
    Mar 2017
    Thanks guys. That worked. I put the left leg in the shoe hole, then hooked it over the post and was able to pull the right leg of the spring into the right shoe hole by hand.
  1. 1985 z50r engine
    By 3rtfan in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-27-2016, 07:39 AM
  2. 1985 z50r
    By Xare50 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-04-2014, 09:00 PM
  3. All Original 1985 Z50R
    By bo woods in forum Complete Bikes For Sale - All makes and models
    Last Post: 11-18-2011, 04:08 PM
  4. 1985 Honda Z50R
    By njdpo in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 01-13-2010, 10:10 AM
  5. flywheel for a 1985 z50r
    By sketchycheck in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 07-22-2009, 04:27 PM
