Resurfacing Brake Drums?
This is a discussion on Resurfacing Brake Drums? within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Has anyone ever had their brake drums resurfaces? If so, are there any tricks? My initial thought is how they would chuck it up and, ...
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By elixur
Thread: Resurfacing Brake Drums?
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Has anyone ever had their brake drums resurfaces? If so, are there any tricks? My initial thought is how they would chuck it up and, well, where to actually take them to get done.
    Currently, I have 2 sets of 3-bolt R hubs that I'd like to get in perfect order. Anyone have any idea on minimum, or rather maximum diameter these can go?
    As these seem to be getting harder to find in near mint condition, I'd like to save the ones I have to use on my road and mud setups.
    Sent from my iPad using Tapatalk
    50 Nuts
    Fat Tires Rule
    tmas's Avatar
    Apr 2005
    TO
    Quote Originally Posted by 66Cooper View Post
    I've never resurfaced them but here is the specs from the Honda Z50R manual. The first pics are for the front.
ID:	204481   Click image for larger version.
    tmas's Avatar
    Apr 2005
    TO
    This is the specs for the rear brakes.
ID:	204497   Click image for larger version.
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    So I have half a millimeter to work with?? That doesn't sound like a lot.
    50 Nuts
    Fat Tires Rule
    tmas's Avatar
    Apr 2005
    TO
    That's right and it not very much.
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    You might find a brake drum hone at your local auto parts store that will work, just to de-glaze them. I think most folks just clean them up with emory cloth.
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    I know that the front drum felt out of round when trying to setup pad clearance.
    Does anyone have specs on the larger, 4-bolt hubs? Do they have more meat to work with?
    50 Nuts
    Fat Tires Rule
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    The wear limit for a 4-bolt hub drum is 111mm. Can't find the original diameter.
  10. #9
    nielspbr's Avatar
    Feb 2008
    [source, z50j01.pdf page 114]
    Inner diameter of drum 110.0 - 110.3mm, replace at 111mm
  11. #10
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Great info guys. Thanks!
    Now, just have to figure out what to do.
    50 Nuts
    Fat Tires Rule
  12. #11
    Moderator
    is Defying the laws of
    tradition...
    RAZZO's Avatar
    Jun 2005
    NEW JERSEY PINELANDS
    My way. Media blast them. Works perfectly. Set of TBparts brake shoes and you have super brakes.
    Razzomoto.com......We are too sexy for our minis. Hidden Content
  13. #12
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Here's something interesting/strange. While replacing the front brake cable return spring (with a much need OEM one) I noticed my brake arm was crazy wobbly. It moved back and forth with no resistance, until you could feel the brake pad engage...but totally free and terrible before that. Long story short, it turned out to be the brake show return spring/horseshoe that came with my kitaco race pads. It was fouling in the inner portion of the hub that houses the wheel bearing. Basically opening them up so they were doing nothing. Not sure how I missed this before. Replaced it for an oem spring/horseshoe and they work perfect.
    Guess you can't even trust the Japanese companies to do things perfect anymore
    50 Nuts
    Fat Tires Rule
  14. #13
    is Leaning heavily towards
    unloading some minis.
    elixur's Avatar
    Dec 2007
    Washington
    Quote Originally Posted by RAZZO View Post
    That's what I do too. Throw em in the blasting cabinet taped off and blast away. After a couple minutes ur good to go.
    RAZZO likes this.
  15. #14
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    I wish that method would be all I need to do to get my sets back. Mine have uneven wear/warping. All mounted up, you could spin the wheel and it would not make it a full 360.
    50 Nuts
    Fat Tires Rule
  16. #15
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Thinking about that spring interference again, I'm sure the spring would fit an xr/crf 50 with no problem. Maybe the z50R hubs have a little more material in there.
    50 Nuts
    Fat Tires Rule
  1. crf50 brake drums
    By Woodyswagon89 in forum Bikes and Parts Wanted - All Makes
    Last Post: 03-10-2013, 09:40 AM
  2. There's just two sizes of brake drums, correct?
    By RobbMeex in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-31-2010, 12:20 AM
  3. Question about brake hubs and drums
    By Hondaminitrailman in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 01-05-2010, 10:13 AM
  4. Need crf 50 brake drums and hardware
    By hank in forum Bikes and Parts Wanted - All Makes
    Last Post: 03-28-2009, 12:09 AM
  5. WTB: Stock brake drums
    By dville_gt in forum Bikes and Parts Wanted - All Makes
    Last Post: 09-14-2008, 10:07 AM
