s65 front end swap complete
This is a discussion on s65 front end swap complete within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I know there are a couple of s65 riders in here so I thought Id post up a pic of my just-completed front end swap. ...
Results 1 to 13 of 13
    モンキ's Avatar
    Jun 2013
    south
    Should work on anything like an s65, c100, c110, c70, ct90, ct110, etc.
    Kawasaki KLX140 front end. Forks shortened 4.5". s65 stem welded into KLX lower triple.
    That's it. Bolt it on and go really. A couple other small details that id be happy to share with anyone wanting to give it a go and get some real front brakes and suspension.
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    How do you shorten the forks? Looks great!
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Totally changes the look with thar front end and brake setup. Looks the biz
    50 Nuts
    Fat Tires Rule
    モンキ's Avatar
    Jun 2013
    south
    Thanks guys.
    I sent the forks to a machine shop in Indy. The guy is a flat tracker and does this all the time. 50 bucks per leg and the work was perfect.
    Seemed cheap to me.
    This is the guy that did it and a video of him doing a set.
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    Wow! That's was both impressive and intense. Very cool and thanks for sharing.
    50 Nuts
    Fat Tires Rule
    sharky nrk's Avatar
    Feb 2015
    Looks great!!!
    モンキ's Avatar
    Jun 2013
    south
    Thanks guys. Currently hooking up a TrailTech Vapor as well so Ill have speedo, tach, engine temp, shift light etc. These things are cool.
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    I LOVE my trail tech. Such a nice little bit of kit for the money. Take your time and really get the tire diameter dead on and the mph' were be perfect.
    50 Nuts
    Fat Tires Rule
  10. #9
    HondaZrider's Avatar
    May 2008
    Los Angeles, CA
    Quote Originally Posted by モンキ View Post
    The vapor is a nice little computer. Love mine.
  11. #10
    モンキ's Avatar
    Jun 2013
    south
    Quote Originally Posted by 66Cooper View Post
    Quote Originally Posted by HondaZrider View Post
    So let me ask a question. If you run it off of its internal battery and that battery goes dead, do you have to recalibrate the thing all over again?
    Or if you run it off the bike battery and have to unhook your battery and the internal battery is dead do you have to recalibrate?
    Im unclear of those things and so have delayed the install since I haven't decided how I want to power it.
  12. #11
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    If you can, run it off the bikes battery. You don't get the shift lights and the back lighting (I believe) off internal only.
    I know I have had to change the internal battery on mine once already and I'd like to say it saved all the data. It was forever ago so I could be wrong.
    50 Nuts
    Fat Tires Rule
  13. #12
    May 2008
    Los Angeles, CA
    I run mine off the battery for the reasons @66Cooper says.
  14. #13
    モンキ's Avatar
    Jun 2013
    south
    Thanks for the tips. Hooking up to the battery then.
    Today I did 90% of the work. Just a little more to do then the calibrating and it should be working.
    Hoping to ride it to work Friday so gotta get it wrapped up before then.
  1. Complete KTM 65 Front End and Complete Pitster Rear End
    By hernpj01 in forum KLX110/Midsize Parts for Sale
    Last Post: 06-27-2014, 07:33 AM
  2. '79 XR80 front end swap
    By GSjimmy in forum Vintage Honda XR75 and JDM Vertical Motors
    Last Post: 01-03-2013, 10:50 AM
  3. 150F Front End Swap............ ???
    By MAZZ77X in forum Honda CRF150R And CRF150F
    Last Post: 10-06-2010, 01:06 AM
  4. ktm 65 complete front end kx 65 complete rear end
    By mab in forum KLX110/Midsize Parts for Sale
    Last Post: 09-18-2010, 12:20 PM
  5. XR75 front end swap?
    By zMan in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-16-2005, 03:22 PM
