Advice For Stripped 1977 Z50
This is a discussion on Advice For Stripped 1977 Z50 within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; New member here, looking for some advice. I picked up a total rust bucket of a 1977 z50 last year and have been slowly trying ...
Results 1 to 2 of 2
    Walking Carpets's Avatar
    Apr 2017
    Nashville, TN
    New member here, looking for some advice. I picked up a total rust bucket of a 1977 z50 last year and have been slowly trying to get it sorted out. Painted everything and replaced the tires, tubes, points, lights, piston, chain, handlebars, carb, tank, and exhaust. Got it running enough to ride it down the street today, which was fun, but it's still not quite right (I think some carb issues) and it's leaking oil from the valve cover, kick start, and close to the sprocket.
    I really like working on bikes and fixing them up, but whoever had this bike before me absolutely butchered it. A ton of bolt holes have been stripped, and threaded for SAE, and stripped again. Working on it has been a nightmare as a result. The intake valve tappet cover is stripped and I can't get it off, the sprocket cover bolt holes are stripped, several hub bolt holes are stripped, the intake boot bolt holes are stripped, and one wheel sprocket bolt is stripped. It's driving me crazy having a mixture of metric and SAE stuff, and I can't do some simple maintenance like setting the valve clearance.
    All that to say, I'm looking for some advice on how to proceed. My biggest issues are the stripped manifold intake and tappet cover. Should I just replace the top end, or would it be worth looking into something like a Lifan engine since other things are stripped and leaking oil? Definitely not trying to restore this thing to show room condition, but I want it to run and be reliable.
    Here's the day I picked it up. Click image for larger version.
    And as she sits today. Click image for larger version.
    MMR
    MMR is offline
    MMR's Avatar
    Apr 2016
    Boise ID
    If your not doing a full restoration on it I would say save $$ and do China engine. But if your able to do engine work top end is pretty easy and you could. Heli coil the top end parts
    Mike's MiniTrail Restorations
    Mikesminitrail@gmail.com
    Buildin them the old fashion way, one at a time
  1. 1977 Z50 has no third gear help...
    By THUCK in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-16-2013, 04:29 PM
  2. 1977 Honda z50
    By kgmx856 in forum Feelers and What is my bike/parts worth?
    Last Post: 01-31-2012, 04:22 PM
  3. just bought a 1977 Z50
    By MotoKidKevin in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-23-2009, 08:43 PM
  4. 1977 Z50 not running right
    By kxfracer108 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-23-2007, 12:03 AM
  5. 1977 Z50 help
    By trevdog in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-14-2006, 07:11 AM
