Making a 88 z50 from a 80 frame
This is a discussion on Making a 88 z50 from a 80 frame within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; So I'm building the gas tank bracket and rear seat bracket. If somebody could get me some measurement s I would appreciate it. I need ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Like Tree2Likes
Thread: Making a 88 z50 from a 80 frame
    Bonedaddy's Avatar
    May 2017
    I need the depth of the rear seat bracket ,and a pic and a measurement on how tall the gas tank bracket height.
    Thank guys in advance
    Bonedaddy's Avatar
    May 2017
    Made the seat bracket,still need to weld in tube.
    Bonedaddy's Avatar
    May 2017
    They sent me the wrong gas tank so I'm in limbo till I get that .
    How is the front number plate attached ,I know the tabs I will weld in but is it screwed into the handle bars ?
    tmas's Avatar
    Apr 2005
    TO
    Quote Originally Posted by Bonedaddy View Post
    A few pics for you.
ID:	208905   Click image for larger version.
ID:	208913   Click image for larger version.
    Bonedaddy's Avatar
    May 2017
    Thank you. That makes more sense. More welding.
    I've had this bike since new in 1980. I was gonna restore it to original but.... plenty do that .
    Thanks again . Now I just need to how that seat sits in that grove in the front. Is there something in the center or is that for the bolt for the gas tank that it needs the u shape front?
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    The rear tank mount is raised up off the frame so the front of the seat slides under it and holds the seat in place. The bolt for the gas tank mounts to that.
    - dirtbkr188 -
    tmas's Avatar
    Apr 2005
    TO
    The front of the seat goes under the bracket that the back of the gas tank bolts to. Have a look at the pics. If you need more let me know.
ID:	208929   Click image for larger version.
ID:	208937   Click image for larger version.
ID:	208945   Click image for larger version.
    is loosing screws all the time...
    Gronk's Avatar
    Nov 2009
    This is exactly what I want to do with one of my Z50 frames.
    Sean Hidden Content
    Nullus Verreor ex Terra Incognita
  10. #9
    tmas's Avatar
    Apr 2005
    TO
    BTW.... If you can see the rubber grommets on the side of bracket that the tank bolts to, the grommets are used to secure the rear cowl.
    1999 Honda Z50R A SEAT | Cheap Cycle Parts
  11. #10
    Bonedaddy's Avatar
    May 2017
    Thank you only pic I didn't have . TB seat is slightly different.
    I will send you guys pics on what I've made so far. I have to bend some pipe for the grab bar . I got some ideas for the side panels brackets .
    I wonder how manys guys would convert their 79 thru 87 if there were brackets.
    This is what I've learned so far. Work from the tank back . You tank bracket is the same . You have to drill out the spot welds on the bracket that the old gas tank mounted to. You can leave you coil mounted where it is due to the recess in the seat.
    Also instead of using the stock 79 pipe I went with new 88 pipe TB offers. It has a larger header and all the correct angle sheild for cheap.
    I think $372 with shipping on seat,tank,all pastic,and exhaust gasket. I think few bucks for grometts .
  12. #11
    Bonedaddy's Avatar
    May 2017
    Well got rear bracket finished. Waiting on tank so in the mean time painting shocks and welding up number plate brackets.
    Thanks again guys for your help.
ID:	209001   Click image for larger version.
ID:	209009   Click image for larger version.
  13. #12
    Bonedaddy's Avatar
    May 2017
    So paint shock tahitian red springs and gold body's what do you think ? Or should I do the silver?
  14. #13
    Bonedaddy's Avatar
    May 2017
    Had ordered this paint 10 years ago to restore. It's still amazing how well it sprays .its by color rite
ID:	209025   Click image for larger version.
  15. #14
    50race's Avatar
    Apr 2004
    North Vernon, IN
    Now you have me thinking of converting my +3cm frame to my later style tank and bodywork
  16. #15
    Bonedaddy's Avatar
    May 2017
    Went with silver for shocks. Look like new . Tonight I'm focusing on the front number plate.
  1. HELEN: Davmo's Aluminum Frame Z50. Honda Z50 alloy monkey
    By davmo in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-21-2015, 09:39 AM
  2. Did bbr stop making perimeter frame?
    By ducKhunt in forum CRF50
    Last Post: 08-20-2012, 02:34 PM
  3. making my z50 a little more comfortable
    By malibusteve in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-30-2009, 09:03 PM
  4. 1984 z50 making a loud noise in motor. HELP!!!
    By grw66 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-21-2008, 05:14 PM
  5. z50 hardtail frame and 2 z50 motors dont know what to do!!
    By FASTEST*IN*AZ in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-30-2006, 06:48 PM
