re running fuel lines '93 ct 70
This is a discussion on re running fuel lines '93 ct 70 within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; My fuel lines are original and are splitting at the petcock. I have trimmed to the point where they barely reach. I really need to ...
Results 1 to 6 of 6
    Expygator's Avatar
    Jun 2012
    Nashville, TN. (Smyrna)
    My fuel lines are original and are splitting at the petcock. I have trimmed to the point where they barely reach. I really need to run new lines.
    1. Where can I find a diagram or a "how to" for this?
    2. What size line and how many feet?
    3. Any do's and dont's for this process?
    Any info would be appreciated.
    Thanks!!
    Hidden Content
    1993 CT70, stock...919 miles
    SEAHAWKS's Avatar
    Apr 2017
    I just rebuilt my fuel system inside and out. You dont need a diagram its that easy.
    Throw your old hoses away and order new stuff here:
    http://dratv.com/noname160.html
    I ordered 2 feet of line and 8 new clamps, plus 2 new fuel filters. Before you put the hoses on your tank, slide the clamps on the end of the hoses around 1/4" +/-.
    This makes it easy to get them over the circumsized head, lol! Pull your new lines thru the opening and reinstall your tank.
    *** Before you start, remove the airbox its easier..... or leave it in, youll figure it out.***
    After your lines are thru, you should reinstall the airbox & begin trimming your fuel lines to desired length.
    Again... you want to install the clips on your hoses before you push in your filters.
    After the clips are on slide the fuel line over the filter, it will be a tight fit but its supposed to be tight.
ID:	210458   Click image for larger version.
ID:	210466   Click image for larger version.
ID:	210474   Click image for larger version.
    Expygator's Avatar
    Jun 2012
    Thanks for the great info. I am puzzled though. I do not have fuel filters in line. Should I have them? Did the '93 come with them? I haven't removed the tank so I don't know whats under there.
    Hidden Content
    Expygator's Avatar
    Jun 2012
    Also, how do I know what diameter hose to use?
    Hidden Content
    SEAHAWKS's Avatar
    Apr 2017
    You can start by removing your gas tank and inspecting it yourself.
    gary s's Avatar
    Oct 2008
    Algonquin IL
    Also mark which line is the main and which is the reserve before you reinstall the tank,you won't be able to tell the difference once it's in. IMHO extra fuel filters are a band aid to another problem. Clean the tank if it has gunk in it and keep your fuel clean
  1. Fuel lines replacement
    By Expygator in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-05-2016, 04:20 PM
  2. Good place for fuel/vent lines
    By dccycles in forum CRF50
    Last Post: 03-09-2013, 01:16 PM
  3. Finding green fuel lines?????
    By Jimi86 in forum Roost Area
    Last Post: 04-26-2012, 10:32 PM
  4. colored fuel lines
    By mike3770 in forum KLX110, DRZ110, TTR90
    Last Post: 04-17-2012, 02:32 PM
  5. ct 70 fuel lines question
    By Reebo in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-11-2008, 09:12 AM
