Alternative ( brighter ) head light bulb for ct 70.
This is a discussion on Alternative ( brighter ) head light bulb for ct 70. within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Is there a bulb available ( led or hid) that will work in a '93 ct 70? Looking for something that won't break the bank, ...
Results 1 to 4 of 4
    Expygator's Avatar
    Jun 2012
    Nashville, TN. (Smyrna)
    Is there a bulb available ( led or hid) that will work in a '93 ct 70? Looking for something that won't break the bank, if there is such an animal. Maybe a retro-fit where someone has made something that works?
    Hidden Content
    1993 CT70, stock...919 miles
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    What type of bulb is currently in there?
    50 Nuts
    Fat Tires Rule
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    If it is something like a standard 12v 30/30 bulb in there, there is a halogen version that fits. At least in a china reflector.
    (Only weird thing is that the connections of dimmed light and full beam are switched around)
    Till now I had no honda bulb failing on me. (49cc instead of my big cc china builds, lot less vibrations depending on engine used.)
    66Cooper's Avatar
    May 2005
    Dirtey Jersey
    There is a bit more to consider when replacing bulbs. What type of lens/housing are you using? Plastic or glass? Metal or plastic? How are the wires in your harness? Can they handle more watts? How much power is the stator pushing and are you running the lights off the battery or off the stator?
    50 Nuts
    Fat Tires Rule
  1. Light bulb doesn't light during points check
    By RobGPalmer in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-17-2016, 08:47 AM
  2. Brighter head light bulb
    By Expygator in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-08-2016, 03:51 PM
  3. 6 Volt Tail Light Bulb
    By jymisuncst in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 12-04-2009, 08:26 PM
  4. Replies: 17
    Last Post: 01-15-2007, 07:30 PM
  5. Replies: 21
    Last Post: 01-04-2005, 07:57 PM
