Removing QA50 Tires
Removing QA50 Tires
This is a discussion on Removing QA50 Tires within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I ordered new tires for my QA50. Now how do I remove the old ones? I want to save the inner tubes. Are there any ...
Results 1 to 3 of 3
    SEAHAWKS's Avatar
    Apr 2017
    Removing QA50 Tires
    I want to save the inner tubes. Are there any tricks all you pros use to remove the old ones?
ID:	210977   Click image for larger version.
    SEAHAWKS's Avatar
    Apr 2017
    Ahhh ha, I figured it out! Im going to bead blast the rims and probably going to have them powder coated along with my frame.
ID:	210993   Click image for larger version.
ID:	211001   Click image for larger version.
ID:	211009   Click image for larger version.
ID:	211017   Click image for larger version.
ID:	211033   Click image for larger version.
    SEAHAWKS's Avatar
    Apr 2017
    Now im going to remove the old paint off my wheels with this paint remover from Home Depot.
    It worked great for removing the original paint off my QA50 fuel tank. It only cost 10.00, im hoping to have them painted before the new rubber arrives!
ID:	211202   Click image for larger version.
ID:	211210   Click image for larger version.
ID:	211170   Click image for larger version.
ID:	211178   Click image for larger version.
  1. QA50 4.00-5 Tires
    By GregH in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 04-26-2017, 09:49 AM
  2. QA50 in need of help
    By pyrOman in forum Introductions
    Last Post: 06-23-2016, 11:48 AM
  3. Qa50 .....what's there value
    By JonDancer in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-27-2014, 06:34 PM
  4. Holy Crap! Removing and mounting tires on original split rims
    By Maxstang in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-24-2013, 07:42 PM
  5. Qa50 k0
    By fujioko in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-22-2008, 02:37 PM
