CT70 Valve Seat Cutting
This is a discussion on CT70 Valve Seat Cutting within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; I have a few 70 heads that need to be rebuilt. Long story short, Im looking for a Valve Seat Cutter set/kit that will resurface ...
Results 1 to 9 of 9
    SEAHAWKS's Avatar
    Apr 2017
    I have a few 70 heads that need to be rebuilt. Long story short, Im looking for a Valve Seat Cutter set/kit that will resurface the old valve seats.
    I tried a few local machine shops with no luck, so I would rather buy my own tools to do the job.
    What size cutters do I need to buy & what angle do I need?
    loopiemclooperson's Avatar
    Oct 2011
    Maple Valley WA
    A neway valve seat resurfacer is what you are after. Here is an example...
    http://www.cylinderheadsupply.com/km2487.html
    You can piece them together more cost effective then that kit, but it would do them all.
    Sent from my SCH-I545 using Tapatalk
    Oct 2011
    Maple Valley WA
    Here is the upgrade kit for small engines like horizontal hondas....
    http://m.ebay.com/itm/Neway-Valve-Se...-/192138289231
    Seems like it is only missing the t handle and the cutter blades.
    SEAHAWKS's Avatar
    Apr 2017
    Thanks for the reply! In the 2nd link you posted, is that kit the one I need to buy?
    I know valve sizes vary a little. Will those 1" cutters work on both the intake and exhaust?
    After rebuilding my 70 im sure that lapping my valves is not good enough. Today im getting a compression tester to see what it reads.
    Oct 2011
    Maple Valley WA
    IIRC most ct70 or copy heads have 5mm or 5.5mm valve stems. The neway guides adjust a bit each way. The 1" cutter bodies are what you need. The kit in the second link is not complete. It is for somebody that already has a kit with the larger guides and cutter bodies. You would need cutter blades and a "T" handle to make it work as a starter kit. Do some research or talk to some vendors they might be able to help you out?
    SEAHAWKS's Avatar
    Apr 2017
    How does this kit look? Will it work for my application?
    VALVE SEAT CUTTER SET KAWASAKI HONDA YAMAHA CARBIDE TIPPED 24 PCS MODERN BIKES | eBay
    http://m.ebay.com/itm/192172468826?_...75&_mwBanner=1
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I'd have some serious doubts about the quality and precision of The kit, especially because of the price and where it is coming from. I also don't think the Honda valves have a 70° edge, I think they are 45° and 60°, for some reason.
    - dirtbkr188 -
    tmas's Avatar
    Apr 2005
    TO
    A good thread to read..... Where's Storminnorman these days?
    Anyone cut their own valves here?
  10. #9
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    Quote Originally Posted by SEAHAWKS View Post
    That depends on what all heads you want to be able to cut the seats on. the honda 70 heads depending on year will either have a 5.5mm stem or a 5mm stem. intake valve again depending on year will either be a 25 or 23mm and exhaust will be a 22mm or 20mm. if your only going to cut seats on 70's you can save yourself a few bucks and just pick up the bare min needed to do those valve sizing and stems but... if you have other minis you want to recut seats on the full kit will be the better choice.
  1. 1979 CT70 valve tick? Normal?
    By 311unity13b in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-19-2016, 09:04 PM
  2. CT70 Valve help
    By Hoopcat in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 04-11-2013, 12:37 PM
  3. Remolding valve exuast seat valve seat.
    By epod in forum Chinese/Import Minis - General Discussion
    Last Post: 07-21-2010, 11:19 PM
  4. Best way to fix a tweaked valve seat?
    By UpOn2PassingYou in forum Roost Area
    Last Post: 02-27-2009, 10:04 PM
  5. 28/24 valves, valve seat help please :)
    By Andoru in forum Chinese/Import Minis - General Discussion
    Last Post: 08-15-2007, 05:12 PM
