aftermarket exhaust and side plate
This is a discussion on aftermarket exhaust and side plate within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Anyone know if, say, minigunz exhaust would work with the right side plate on my 1980 Z?? My '79 only has the left plate, and ...
Anyone know if, say, minigunz exhaust would work with the right side plate on my 1980 Z?? My '79 only has the left plate, and I want to end up with two to keep the Elsinore theme going. Also how does the minigunz compare to the T4 Pro Circuit system; noise vs. power?
02-11-2008 01:43 PM
Re: aftermarket exhaust and side plate
I can't say for sure,but I think as long as the exhaust is made for a soft tail it'll work.
If you're putting a right number plate on a 1979 Z50R, you'll need to drill a 1/4 in. hole in the frame for the 1980-1987 style Z50R right side number plate to fit and then put a nut on the other side. Weld the nut on if you can to make it easier. I'm just letting you know this because I can't tell if you're putting the number plate on the 79 or the 80. And I've heard the ProCircuit performs great but they are both loud. I don't know if either exhaust will work with the number plate bracket though. I'd like to know the same thing. Let me know if you find out first, I'll do the same.
Have both pipes on Z's w/ 88cc RH CRF motors. Both are excellent. Pro cir. pipe is a bit louder than the Minigunz. Pro C. is $300. Brushed finish. Minigunz $225. Stainless and polished can. Both are good sounding pipes. Great performance. Your choice on look & finish. Can't go wrong with either.
Razzomoto.com......Keepin old school cool.
i got my pc exhaust for 230 shipped. havent started it yet so cant tell you on the noise. and it looks like itll be hard to make a #plate work on that side.
82 z50r 88cc race machine
06 crf450r
Class A goonrider
Originally Posted by
arlindsay1992
I am doing over my '80 Z which HAD two plates, both are missing. My '79 only has the stock LH plate. I am just looking to see if anyone has been able to put both plates on with an aftermarket exhaust, such as the two brands listed.
Thanks for all the input, but my actual question hasn't been answered. (Not trying to be a jerk, just looking for some info, so I don't waste money buying replacement number plates, just to not have them fit.)
Oh. Right plate is possible with stock 80's exhaust on 79 frame. I have no idea what changes with the aftermarket exhausts. I hope to know someday. Hope that clears up what I said before.
Well then do like I do. R & D. Make it work. Make a bracket or mod your stock one with spacers or such to fit over the exhaust. You'll be the first one to do it on here that I've seen. Waste money?? Your building a custom Z! We all waste money on here!
But its fun!
Yeah. That's what I would probably do because I don't like the way it looks without the right number plate.
RAZZO
But its fun!
Waste Money? It's uh, uh, a good investment...
(borat pause)
NOT!
RAZZO
But its fun!
Good advice, I'll try that....anyone know a inexspensive souce for white plates all around? I see them on Ebay for $25 plus shipping, too rich for my blood
Honda Trail Bikes sells all the color oval plate for like $18 each. That's where I'd get them from if I needed them.
Click here. Scroll about halfway down.
arlindsay1992
Thanks....I've seen stuff when I've browsed all the sites, then when I actually need something, I can't find it. At least for a good price!! That isn't a bad deal, but ALL the plates are missing on the '80. Oh well, gotta spend some cash once in a while.
The 1980 plates wouldn't do you any good though would they? Those were Tahitian Red and you want whatever white they used on the 82 models. If you had the red ones, it would be even harder to convince yourself to buy a full set of white ones.
arlindsay1992
Yeah, I'm going to buy white, then paint silver/green in Elsinore fashion.
But I got none....dammit.
Kind of a hi-jack to my own post, but, does anyone have a video they can post showing minigunz & Pro Circuit exhaust sound difference?? This would be two videos, sorry!!
I just got the go ahead from the old lady to order it!!
- You may not post replies
- You may not edit your posts
Forum Rules
