ct70 K1 fork rebuild?
This is a discussion on ct70 K1 fork rebuild? within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; My forks leak and are super soft. I could rebuild them but I'm not sure if it would be worth it. With stiffer springs and ...
Results 1 to 7 of 7
    orangeCT's Avatar
    Feb 2008
    My forks leak and are super soft. I could rebuild them but I'm not sure if it would be worth it. With stiffer springs and new seals would they still bottom so easy?
    is Dem Tins
    Pierce's Avatar
    Feb 2006
    Evanston Il
    Re: ct70 K1 fork rebuild?
    What year CT do you have and which version of forks do you have?
    orangeCT's Avatar
    Feb 2008
    72' K1. Version? I didn't know they made different ones other than K0?
    orangeCT's Avatar
    Feb 2008
    is Building Resto-Mod CT 70's
    buellboy's Avatar
    Mar 2006
    Iowa
    I just rebuilt my K1 resto-mod forks. I installed the stiffer springs, 15wt. fork oil and new seals from DrATV. The forks are substantially stiffer. I would suggest replacing the rear shocks as well. Good Luck!
    orangeCT's Avatar
    Feb 2008
    Which rear shocks did you do? Do your fronts bottom out coming down from a wheelie?
    buellboy's Avatar
    Mar 2006
    Iowa
    OrangeCT,
    I used a pair of shocks from DrATV. I have a complete new set available that are a great match for the heavier springs offered by DrATV. PM me is you are interested.
    No bottoming with the fork rebuild.
1972 honda ct70 k1 front fork rebuild
ct 70 shock rebuild
ct70 fork oil
ct70 fork oil capacity
ct70 fork rebuild
ct70 front fork rebuild
ct70 hydraulic fork rebuild
honda ct70 fork oil
honda ct70 fork rebuild
how to rebuild ct70 forks
how to rebuild ct70 front fork
how to rebuild ct70 front forks
