AHP 4 speed transmission
This is a discussion on AHP 4 speed transmission within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Does anybody know anything about the AHP 4 speed for 150 dollars?...
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
    nlipshutz's Avatar
    Aug 2008
    Roseburg, OR
    is an asshole
    chasetheface123's Avatar
    Nov 2007
    Boyne City Michigan
    Re: AHP 4 speed transmission
    its a great kit and you should buy one right now! seriously tho their real nice and theirs a how to vid on teh bottem of the item description that shows you erthing
    nlipshutz's Avatar
    Aug 2008
    Roseburg, OR
    Quote Originally Posted by chasetheface123
    do you if it wil work in a 6v z50
    is an asshole
    Nov 2007
    Boyne City Michigan
    that i do not. try sending an email to ahp (mark) or sending him a pm on here. he has an account and you will see it on teh vendor side the right side of the top when you are at the home page,
    he will tell u erthing u need
    is wants to buy a motor with a
    special clutch and some sort
    of 88 with race head. pm me
    moto234's Avatar
    Apr 2008
    Ukiah CA MENDO 707
    i would think it would fit in a z50 because it uses z50 sprocket. but i could be wrong, just ask mark and you'll be good
    is an asshole
    Nov 2007
    Boyne City Michigan
    yeah
  7. #7
    arlindsay1992's Avatar
    Mar 2006
    Northern Virginia
    It will fit.
    E-mail: arlindsay1992@gmail.com
    Myspace: http://www.myspace.com/arlindsay1992
    Skype: arlindsay1992
    AIM: arlindsay1992
  8. #8
    nlipshutz's Avatar
    Aug 2008
    Roseburg, OR
    thanks guys
  9. #9
    EddieNewYork's Avatar
    Oct 2007
    Los Angeles, CA
    Just a quick hijack question...
    If installing this in conjuction with a TB manual clutch, will it let you start in any gear while holding in the clutch lever or no?
  10. #10
    Mar 2006
    Northern Virginia
    No. The TB clutch needs to be engaged(don't pull the lever) to start the motor. The kickstart force goes through the clutch so you must be in neutral with the clutch engaged to start. Well, you can start in gear but you still can't touch the clutch lever and once it starts you will promptly lose control of the bike. So start in neutral.
    AIM: arlindsay1992
  11. #11
    Oct 2007
    Los Angeles, CA
    Cool doode, thanx.
  12. #12
    is in need of more ZB50's
    tmas's Avatar
    Apr 2005
    ...otnoroT...
    Clutches mounted on the end of the crankshaft require you to start them in neutral. If the clutch is not crank mounted it will start in any gear when you pull the clutch in.
    Oct 2007
    Los Angeles, CA
    Quote Originally Posted by tmas
    Thanx tmas.
  14. #14
    englocon's Avatar
    Jul 2009
    Raising this post from the dead.
    I know a couple of people said that this transmission kit will work with a Z50, but are there any extra parts that need to be changed out, such as the kickstarter spindle, to run this kit in a stock 6v 1979 Z50R motor?
  15. #15
    Mar 2006
    Northern Virginia
    No. It will bolt in. Even uses the same sprockets. CRF's need to convert over to Z50 sprockets when they buy the kit.
    AIM: arlindsay1992
  16. #16
    englocon's Avatar
    Jul 2009
    Quote Originally Posted by arlindsay1992
    Sweet! I know what I'm doing with my birthday money now!
  17. #17
    blackhatch's Avatar
    Jan 2007
    Warren Ohio
    yeah im thinking about doing this too and i had some q's. is there anything else i should do to the motor while i have it all apart? i mean in the cases? like should i replace shift forks or shim it anywhere? bike runs/shifts fine now but to avoid a future tear down,what are the weak spots in the motors(2007 crf50)?
  18. #18
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    AHP trans comes with new forks and drum. It's a drop-in. If you wanna get ambitious, you could source some different shim sizes to snug it up. I've put a bunch in, and not had a come-back, though. Two more going in this week. Remember that they're still small gears, so you need to shift right. Heel-slam downshifts will get you in trouble, same as with a Honda 4 speed. I took a spin around the block yesterday on a 117 4-speed. Nice
  19. #19
    is disgusted by all of it...
    ShapeShifter's Avatar
    Sep 2008
    Vacaville, CA
    My mechanic is installing an AHP 4 speed tranny for me and says it only shifts into two gears at one (which of course is bad). He is suspicious because it comes pre-assembled.
    I have only heard good things about it, thats why I got it.
    Anyone else have problems with this kit?
    -Todd
  20. #20
    is Eat - Sleep - Work - Live -
    PIT BIKE !
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    none of my customers have had issue
    T Bolt USA - Let's go riding!
    Online Store - Tech Database - Facebook - TheCRKid@TBoltUSA.com - (704) T-BOLT-US - Skype: TBoltUSA
ahp 4 speed
ahp 4 speed not shifting righr
ahp 4 speed problem
ahp 4 speed review
ahp 4 speed schematic
ahp 4 speed sprocket
ahp 4 speed tranny
ahp 4 speed transmission
ahp 4 speed transmission kit
ahp four speed
does ahp 4 speed transmission have neutral
how to shim ahp 4speed
