Z50/CT70 Technical Resources
This is a discussion on Z50/CT70 Technical Resources within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; Here are some technical and pictoral resources for those building up Z50's. Click the links for each segment of information. Z50 Identication Guide, Complete - ...
Results 1 to 5 of 5
Like Tree8Likes
  • 2 Post By tmas
  • 2 Post By tmas
  • 2 Post By tmas
  • 2 Post By tmas
Thread: Z50/CT70 Technical Resources
    Z [OP]
    Z is offline
    is nowhere to be found.
    Z's Avatar
    Sep 2003
    KANSAS
    Honda50.com Z50 Identification Guide
    Z50 Original Model Gallery including all the US and Japanese Models -
    Honda Z50 & Monkey Bikes Original Models Gallery
    CT70 Identification Guide, Complete -
    Welcome to CT70 Identification Guide
    Repair Manuals and exploded parts Diagrams:
    Honda50.com Parts Lists
    Z50 and CT70 Engine VIN Decoder
    Honda50.com Engine Vin Decoder
    Z50 and CT70 Model/Frame VIN Decoder
    Honda50.com Model Vin Decoder
    Gear Ratio and Mechanical Speed Calculator:
    Honda50.com Gear Ratio - Speed Calculator
    Engine Displacement Calculator:
    Honda50.com Displacement Calculator
    Custom Gallery of bikes from around the world
    Custom Monkeybikes From Around the World
    Mikuni VM26 Carb Differences
    http://www.planetminis.com/f14/mikun...ech-94268.html
    Earl's Fittings for Oil Coolers Explained
    http://www.planetminis.com/f14/earl-...tml#post988395
    6V CDI Conversion
    http://www.planetminis.com/f14/cdi-c...ml#post1092336
    Takegawa Thermostat Explained
    http://www.planetminis.com/f14/how-t...ks-117434.html
    http://www.planetminis.com/f14/12-vo...ml#post1292656
    tmas's Avatar
    Apr 2005
    TO
    Here are some links to the Alexman Videos on YouTube, essential Z50 engine building and tuning info:
    Honda TB 88 with RH Installation Part 1:
    Honda TB 88 with RH Installation Part 2:
    How to Install 51mm Stroker Crankshaft (TB 10:
    Race Motor Rebuild:
    How to Install High Volume Oil Pump:
    tmas's Avatar
    Apr 2005
    TO
    How to Install 4 Speed Transmission:
    How the Honda 3 speed works:
    Transmission Overhaul Part 1:
    Transmission Overhaul Part 2:
    How to Install Heavy Duty Clutch Springs:
    tmas's Avatar
    Apr 2005
    TO
    How to Install Clutch Plates and HD Clutch:
    How to adjust Honda clutch:
    How to check valve timing on Honda 50 70 cc motors:
    How to Adjust Honda 50/70 cc Valves:
    How To Set Cam Timing:
    tmas's Avatar
    Apr 2005
    TO
    How to Set Points:
    How to Replace Wheel Bearings:
    TB Parts Honda Z50/ Ct70/ 88cc/ engine rebuild/ AHP 4 speed:
ct70 vin numbers
honda 50 identification
honda ct70 identification
honda ct70 vin decoder
honda ex5 engine diagram
honda z50 engine identification
honda z50 engine serial numbers
honda z50 identification guide
honda z50 models
z50 engine number
z50 engine numbers
z50a-186877 vin
