lifan 125 ignition diagram
This is a discussion on lifan 125 ignition diagram within the Z50, CT70 and JDM Monkeybikes forums, part of the General Talk category; looking for a lifan 125 engine wiring diam gram and maybea link on how to trouble shoot the coils and what not. I think i'v ...
Results 1 to 11 of 11
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    I think i'v had it with the ignition frieing my old man said it was the cdi box and something about the spark plug wiring shorting out on the exhaust pipe apparently thats wrong. if not well i'm getting pissed and it spite of it making me sad just giving up on mini bikes maybe for good cause all my mini bike projects turn out this way horrible and not working.
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    Re: lifan 125 ignition diagram
    Just put a Honda ign. system on it and be done with it.
    The older I get, the faster I was !
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    uuhhh what and how? what parts do i look for any links how much i will only have 66 bucks to spend. i did find this.
    mine does the same d**n thing.Man i am soooo frustrated. fastMC's idea sounds nice. is it common for chines ignitions to fail this last time i was riding it bogged down and died, no spark.
    stevec's Avatar
    Sep 2007
    Check the kill switch or by pass it altogether to test.
    Get a multimeter, read this:
    Dan's Motorcycle "Electronic Ignition"
    Dan's Motorcycle
    and do continuity tests on stator coil, ignition coil.
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    continuity passed gonna get a coil any ways. thnaks for the links i'm reading up right now. also bypassed the kill switch.
    stevec's Avatar
    Sep 2007
    SUPER COIL IGNITION CRF50 CRF XR 50 SSR SDG PIT BIKES Item number: 380069830797
    US $14.95
    "TEC" IGNITION COIL XR CRF TRX Z 50 70 90 125 250 300 Item number: 350115896640
    US $18.99
    CDI
    $10 shipped. Plenty on Ebay.
    ~$25 total, well within your $66 budget
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    Quote Originally Posted by cdoublejj
    Do not bypass the kill-switch, If you close the circuit the cdi is grounded and you won't get a spark.
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    Quote Originally Posted by stevec
    US $14.95
    US $18.99
    CDI
    sounds like the same crap i bought already just more money.
    thanks for the grounding tip nielspbr
  10. #9
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    Ever consider it may be the wiring harness at fault ? Just a thought...Seems you've already replaced everything else ?
  11. #10
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    Quote Originally Posted by FastMC
    yeah i took all the tape off all the connections/solder look good didn't see any scraped wires. the ground was wee bit loose since the nut on the screw was the wrong size. once i read that link what my dad said about it grounding on the exhaust pipe seems like a possibility if it fries again guess that narrows it down pretty good then it's absolutely not fluke .
  12. #11
    thadeus's Avatar
    Mar 2009
    im in the philippines, where can i purchase carburator for lifan 110 saturn shipped to 150cc?
125 pit bike wiring diagram
125cc lifan wiring diagram
125cc pit bike wiring diagram
1p52fmi-k wiring diagram
lifan 125 wiring
lifan 125 wiring diagram
lifan 125 wiring diagram for cl 70 honda
lifan 125cc engine wiring
lifan 125cc engine wiring diagram
lifan 125cc pit bike wiring diagram
lifan 125cc wiring diagram
wiring diagram lifan 125
